New! Dark mode!
(Topic ID: 154128)
FG locked in boot mode
By Bwheels
  • 13 posts
  • 6 Pinsiders participating
  • Latest reply 4 years ago by DeathHimself
#1 4 years ago
Just picked up this family guy and when I turn it on it seems to be stuck in the boot mode. The speakers click and it sounds like it's trying to boot but won't kick over. Any ideas
#2 4 years ago
It looks like when the speakers "pop" the 5v led goes on and off at the same time on the circuit board in the picture
#3 4 years ago
On second glance it is the L18 LED
#5 4 years ago
I reseated everything and it seems to be an issue with the upper playfield I got into test and all the upper playfield switches where throwing errors so I disabled it and was able to play a game. Any thoughts on how to fix the upper playfield issue?
#6 4 years ago
Mine did the exact same thing. I went into test and didn't have any errors. Exited the test and game booted and has played fine since. I hadn't played mine in quite awhile and don't know if that had something to do with it not booting properly. If you find the problem I would like to know as well.
#7 4 years ago
Will do. I will take then upper playfield off tomorrow. Fuse F6 seems to also not be working probably related.
#8 4 years ago
I had the same problem along with many others when I got a family guy a few months ago.. Does it give you the check 12v error fuses 12 + 13 when the speaker popping stops?
When I spoke with Chaz from stern tech support he mentioned removing resister 86 from the cpu(it's a very small mounted component so be careful). My family guy has been trouble free since.
#9 4 years ago
Quoted from Bowlingpin:
Yes it eventually blows the fuses and says check 12V and fuses 12 and 13. how the heck do i remove resister 86?
thanks for the response
#10 4 years ago
Well mine was blowing fuse 9(controlled lamps) but that was because of a bad bridge rectifier. I still had the issue with it not booting after..
Give stern a call first they should be able to help you out.
Yes Chaz told me to remove resistor 86 from cpu. It's quite simple l, I used tweezers and a soldering iron with a very fine tip.
#11 4 years ago
I spoke with tech support at stern and they told me to tighten up the "Heat Shrink" in the upper Left corner of the I/O board. I am not sure what that means. Can anyone clarify?
#12 4 years ago
I had a similar issue on POTC recently. Mine was with the 5v. I had to tighten the heat sink on the 5v rectifier. Check that all of the heat sinks are touching what they should be cooling and snugged down.
#13 4 years ago
Make sure all these highlighted screws and nuts are very tight. These are your heat sinks.
and on your Power Board
$ 54.99
$ 99.00
Arcade Upkeep
Milford, CT
$ 499.95
Pin Stadium Pinball Mods
Sparky Pinball
5,500 (Firm)
Cherry Hills Village, CO
$ 28.00
Arcade Upkeep
