Hi everyone,
I have a 1980 Black Knight and the feature lights have been intermittent for the past six months. Sometimes they work and sometimes they don't. There doesn't seem to be a rhyme or reason or scenario when they work vs don't work. All GI lights work normal. I have checked the obvious and I think there is something on the driver board that is causing the issue. One thing to note is that when powering the pin up the feature lights will flash briefly and then turn off. The same flash happens when turning the pin off.
- I checked all fuses - They are good
- I re-seated all connectors on the power board, mpu and driver boards
- I have 18v coming out of the driver board and traced the 18v all the way down to the lights,
So I think it is not grounding the lights properly???? Perhaps the transistors????
Any thoughts or additional troubleshooting steps I should follow?
Thanks in advance.
-Steve
