(Topic ID: 165609)
Fathom Right Flipper Button Switch Closed
By yyyyyikes
  • 5 posts
  • 2 Pinsiders participating
  • Latest reply 3 years ago by yyyyyikes
#1 3 years ago
Hi anyone and everyone.
In test mode Fathom is reporting that the Right flipper button switch is closed (Number 7),
which i guess is the secondary switch on the cabinet flipper switch.
Could this be due to the diode being faulty? The flippers are un-stagable in play - even when
the secondary switch has clearly not been closed.
Does anyone have photos of the correct installation of the cabinet flipper button switch?
Thanks in advance, also thanks if I'm way off the mark and it's something completely different.
#2 3 years ago
Anything shorting the metal leaf blades on the fiberboard spacers between them ?
#3 3 years ago
hiya, no they look well clear of each other (well clear enough). I guess the thing to do is replace the second switch, I have a few - just no diodes.
#4 3 years ago
i think it may be that there's quite of few switches, or at least a few that are not wired correctly - disconnected one wire from the secondary cab switch and the error disappeared (obviously) just need to wire it correctly.
also, the top saucer rollover is wired in the same fashion (i.e. wrongly).
does anyone have photos of the underside of their fathom?
or could tell me which colors to wire to which parts of these particular switches please - would be a massive help. i guess the only thing that matters with a switch is which direction the diodes are pointing to which wires (which i tested and are ok). i bet once i rewire that saucer (which was acting strangely, it kept shooting the ball out behind the drops), there will be another error.
thanks much in advance!!!!!!
#5 3 years ago
ah, heck, i'm having fun with the schematics now anyhow.
Displays
PinballSolutions.eu
5,500 (Firm)
Cincinnati, OH
$ 149.95
Allteksystems
Third Coast Pinball
$ 9.00
Cabinet Parts
Third Coast Pinball
