You should pass your current playfield on because it doesn't appear to be in bad shape.
Quoted from NightMutilator:I am indeed late to owning this game as I've been looking (should have never waited this long), but now that I have one (thanks to pacman11) I'm hooked... Ordered a gold CPR playfield and am gonna do my first pf swap! Could be the perfect game for horrorhouse fest... hmmmm..... I'm scared.
Nice, definitely fits well in there. When you do the swap, you may want to change out the middle drop target bank to the original "1-2-3" instead of the targets. Knocking down those three in order lights the extra ball target for a few seconds, so having them numbered fits with the game rules.
This is like a horror-themed I-Spy picture, I keep finding new stuff to see. Looks awesome.
Quoted from jahbarron:You should pass your current playfield on because it doesn't appear to be in bad shape.
I for sure intend to. It's in good shape overall. Some planking and the inserts are worn as expected, but pretty decent overall. Once I actually make the swap happen I will have it for sale here on pinside...
Quoted from mattmarr:Nice, definitely fits well in there. When you do the swap, you may want to change out the middle drop target bank to the original "1-2-3" instead of the targets. Knocking down those three in order lights the extra ball target for a few seconds, so having them numbered fits with the game rules.
Yep. I ordered new drop targets before I even got the game for that very reason
Would someone in this group be willing to take a good high rez shot of the original Fathom topper if they have one? Just a simple straight on shot without flash glare. I'd like to create a digital topper for the Visual Pinball version of the game. Thanks.
Quoted from Onevox:Would someone in this group be willing to take a good high rez shot of the original Fathom topper if they have one? Just a simple straight on shot without flash glare. I'd like to create a digital topper for the Visual Pinball version of the game. Thanks.
Fathom didn't have a topper that I know of? CPR made one up though with the girl peering over the side of the boat I believe. Is that what you're looking for?
Quoted from roar:Fathom didn't have a topper that I know of? CPR made one up though with the girl peering over the side of the boat I believe. Is that what you're looking for?
CPR has some images of it on their site. I put the topper on mine, but the individual pieces somewhat obscure each other (intentionally) when installed, so if you need shots of each part, mine may not work. Just let me know.
yes. The CPR one. I love the way that connects the idea with the BG, one of the best toppers. I actually would be fine with it set up so that there is overlap. For the virtual version, I think I'm going to add some animated water under the boat and sunset sky behind it. Matt, if you can take with a solid color behind it that would be great, like black or white. I just need a minimum of 1920x1080, higher better of course. Greatly appreciated.
Quoted from Onevox:yes. The CPR one. I love the way that connects the idea with the BG, one of the best toppers. I actually would be fine with it set up so that there is overlap. For the virtual version, I think I'm going to add some animated water under the boat and sunset sky behind it. Matt, if you can take with a solid color behind it that would be great, like black or white. I just need a minimum of 1920x1080, higher better of course. Greatly appreciated.
Not a problem, should be able to take care of it later tonight.
My advice is to get it running before you focus on the cosmetics...
-New balls, bulbs, Novus, and rubbers.
-Remove the battery on the MPU.
If you need help getting the MPU to boot, let me know and I will either help you fix it over the forum or, try to repair it for you.
Quoted from snyper2099:My advice is to get it running before you focus on the cosmetics...
Just to piggyback on that, I would say to check the fuses before turning it on to make sure they are the right type and rating (and not blown of course).
Quoted from mattmarr:Just to piggyback on that, I would say to check the fuses before turning it on to make sure they are the right type and rating (and not blown of course).
Thanks guys & thanks for the group invite. I know a guy that is into arcade/pinball resto. Due to battery leakage, I pulled that board out. I've heard they can be repaired or replaced. What should I be looking at price wise for either?
V2 Fathom backglasses are done and shipping to us on Weds - so will be available within about a week after that ... same supplier who has worked with us on many other backglasses (Kiss, Firepower, Blackout, Alien Poker, etc) ...
Quoted from PPS:V2 Fathom backglasses are done and shipping to us on Weds - so will be available within about a week after that ... same supplier who has worked with us on many other backglasses (Kiss, Firepower, Blackout, Alien Poker, etc) ...
Will these look different or better than the last run?
Fathom V2 backglasses are in and are stunning ... colors look great and overall great product (same supplier as Kiss, Firepower, Gorgar, Blackout, etc) ...
Side by side comparison of CPR version and Outside Edge
And as for the backside, a noticeable difference:
One thing I noticed about the backside of the glasses was that the Outside Edge (OE) one the mermaid on the right side (if looking at the front of the glass) you can see they partially screened the right side of her body whereas the CPR glass is just blacked out! When I hold the OE up to the light it does allow for light to come through whereas the CPR does not!
One thing about the OE glass is that there is no CREDIT sticker on it! So I guess you have to purchase these separately.
Is the Outside Edge glass the one Planetary Pinball is currently offering as version 2? That version looks more like the original glass. How does it looked compared to the original in the game and backlit? Does the colors and image washout?
Quoted from Orbian:Is the Outside Edge glass the one Planetary Pinball is currently offering as version 2?
yes
Quoted from Orbian:How does it looked compared to the original in the game and backlit? Does the colors and image washout?
Haven't installed it as of yet!
Quoted from bonzo442:A side by side comparison of that would be nice, so far so good though
Agree, unfortunately I don't have an original one that I can take a picture of to compare it to.
The Outside Edge looks more like the original. The CPR one is very dark and the colors look over saturated! I hate to knock CPR but this was the second machine I had with one of their repro glasses, the other was Medusa, and both I wound up selling and replacing as I just didn't like the look of them!
Any chance that anyone has a populated fathom playfield for sale? Playfield can be in any condition.
Anyone have recommendations for color matches/ brands of paint for a fathom cabinet restoration? Thank you for any help you can provide.
Quoted from Tsskinne:Anyone have recommendations for color matches/ brands of paint for a fathom cabinet restoration? Thank you for any help you can provide.
Ironlak, color match to your desire.
Not too long ago, it was posted that Shay was working on reproducing the Fathom glass, and it would be more faithful to the original than the repro that Phoenixarcade, and later CPR did. Is THIS the same project? I'm confused.
BTW, those earlier repros were made from a scan of my glass, and I got the early repro, but am interested in the redone glass, if closer to the original, as my original glass has some lifting. Thanks for any info!
some inspiration
http://aussiepinball.com/index.php?topic=10274.0
Quoted from PPS:Fathom V2 backglasses are in and are stunning ... colors look great and overall great product (same supplier as Kiss, Firepower, Gorgar, Blackout, etc) ...
http://www.planetarypinball.com/mm5/merchant.mvc?Screen=PROD&Product_Code=PPS-G-440-17V2&Store_Code=PP
I wasn’t planning on spending money when I checked back in on this thread but here I am, backglass ordered!
Quoted from BoP:I wasn’t planning on spending money when I checked back in on this thread but here I am, backglass ordered!
If you still have an original Fathom
to compare with the new repo it would be great to get a side by side comparison
Just ordered. Thanks for helping make this happen. The CPR were a great option for people with missing or badly flaking originals but they are just too purple and dark compared to the original.
A few pics of a new CPR playfield that unfortunately has some insert separation, insert sinking, and some pretty wavey clear. This is not from the newest run of playfields so I'm not sure if it is a storage issue. First pic is with the inserts reset and the playfield recleared, 2nd and 3rd pics show the issues.
Quoted from Joey_N:Not too long ago, it was posted that Shay was working on reproducing the Fathom glass, and it would be more faithful to the original than the repro that Phoenixarcade, and later CPR did. Is THIS the same project? I'm confused.
Not sure about the project that was discussed earlier. The Fathom BG that are being sold now at Planetary are a new reproduction. These reproductions were manufactured for Planetary and produced by Bruce at Outsidedge. Original art along with NOS BG were used to make these. The manufacturer was well aware of color vaiations of past repos. This is by far the nicest reproduction available.
Quoted from bonzo442:If you still have an original Fathom
I’d love to see that myself but unfortunately I only have a CPR glass.
Sorry if this has already been addressed elsewhere but I have recently acquired a Fathom (grail pin for me) with redone cabinet, new play field and and back glass etc. Unfortunately, those who restored it didn't change out the dodgy original lamp sockets under the play field. I would like to replace them but was wondering if anyone had experience with this and maybe a part number as there are many different types of lamps sockets. Any advice would be appreciated! Adam
Quoted from adamsebas:Sorry if this has already been addressed elsewhere but I have recently acquired a Fathom (grail pin for me) with redone cabinet, new play field and and back glass etc. Unfortunately, those who restored it didn't change out the dodgy original lamp sockets under the play field. I would like to replace them but was wondering if anyone had experience with this and maybe a part number as there are many different types of lamps sockets. Any advice would be appreciated! Adam
These are the 3 main lamp sockets you’ll need. It’s been awhile since I did mine so I can’t recall if I needed any others or not but I’m sure they were the majority of them.
http://www.rtbb.com.au/catalog/product_info.php?cPath=22_118&products_id=870
http://www.rtbb.com.au/catalog/product_info.php?cPath=22_118&products_id=868
http://www.rtbb.com.au/catalog/product_info.php?cPath=22_118&products_id=3277
Quoted from BoP:These are the 3 main lamp sockets you’ll need. It’s been awhile since I did mine so I can’t recall if I needed any others or not but I’m sure they were the majority of them.
Not sure if Pinball Resource ships to you or not but do check there for sockets too, cheaper per piece but shipping/duty may kill the savings.
Quoted from jgentry:A few pics of a new CPR playfield that unfortunately has some insert separation, insert sinking, and some pretty wavey clear. This is not from the newest run of playfields so I'm not sure if it is a storage issue. First pic is with the inserts reset and the playfield recleared, 2nd and 3rd pics show the issues.
The newest run was better but not perfect and I paid to have it perfected.
Quoted from roar:Not sure if Pinball Resource ships to you or not but do check there for sockets too, cheaper per piece but shipping/duty may kill the savings.
http://pbresource.com/sockets.html
Yes PBR are great and they have a lot of parts you can’t find anywhere else but it’s the shipping and the exchange rate that hurt on any overseas purchase.
Awesome..thank you!
Quoted from TaylorVA:Finally have a set of Fathom rails to reproduce. These will get dyed blue and finished with clear lacquer. Will post some pics when a set is finished.
Taylor, any chance for a second set for a fathom I’m restoring?
I have been getting some good reports on the upgraded ball kickers, with strengthened up sections, found here
https://www.shapeways.com/marketplace?type=product&q=swinkskicker
- lhs white one is the original version and
- rhs blue one (you can pick your own colour) is the strengthened up one
photos from BoP's beautifully restored fathom
Quoted from Skins:Taylor, any chance for a second set for a fathom I’m restoring?
Skins I put you down for a set.
Ordering the kickout plastic now..
What's the deal with the grey spacers in the pic? I haven't started on my restoration, but seems like mine has a stack of some pieces that I didn't think looked original there. How did it ship from factory? Would be neat to have a 3D printed spacer there!
Thanks for reading..
This page was printed from https://pinside.com/pinball/forum/topic/fathom-owners-club/page/7 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
