(Topic ID: 308962)
Fast Draw weak kick outs and Outhole.
By Sea_Wolf
2 years ago
  • 13 posts
  • 2 Pinsiders participating
  • Latest reply 2 years ago by Sea_Wolf
#1 2 years ago
All of the sudden the 2 top kickout holes are extremely weak as well as the Outhole kicker on the ball return.
I cleaned all the switches and checked gaps on the Hole relay, Ball Return relay as well as the switches on Score Motor 1C and 2B but problem still exists.
The game was playing at 100% before this. Any help is appreciated.
#2 2 years ago
Did you check that Motor 4C switch that feeds them all?
#3 2 years ago
Quoted from paulace:
Thanks for that. I meant to include that 4C were the first score motor switches I checked from the schematic but you making me check it again may has solved it. I just noticed a cracked solder tab on the inside switch.
I’ll resolder and report right back. Eyes aren’t what they used to be.
#4 2 years ago
I'm confident that's the problem. Good catch.
#5 2 years ago
Well it looks like what I saw was an unsoldered jumper wire that looks like it goes from the inside switch on 4C to 4B but I resoldered it and no change. Also on the schematic it shows that the wire that you were referring to on 4C should be yellow-red but there are no yellow-red wires on 4C. A double Orange-Red wire to the inside switch but no yellow-red unless I’m reading something wrong.
Here’s a picture of 4C. I took off 4D to see better. If you’re Quick Draw has the same score motor wiring on 4C, I wonder if you see a Yellow-Red wire and where that Jumper wire on the inside switch goes to. Thanks for the help.
B8737C5A-9E17-459B-A843-63677E9F848E (resized).jpegB8737C5A-9E17-459B-A843-63677E9F848E (resized).jpegBA5F2B8C-A55A-45C6-B17B-308A70CE8714 (resized).jpegBA5F2B8C-A55A-45C6-B17B-308A70CE8714 (resized).jpeg
#6 2 years ago
Ha! That's what I get for being confident. *laugh*
I'll check mine out in a few minutes and see what my 4C stack looks like.
Paul
#7 2 years ago
Paul
Thanks Paul. I still think you’re right.
#8 2 years ago
Yeah, I definitely have a YEL-RED wire on the outermost switch - orange jumper on the other side. That switch has the large contacts too, which I'd expect for that high-current job.
You can see the wire color better on this one:
#9 2 years ago
Thanks for the pictures. Yeah mine just has a plain yellow wire instead of the yellow-red but it also has the large contacts.
I’ll do more checking and cleaning. Seems like it almost has to be 4C. Thanks again.
Danny
#10 2 years ago
It seems like the only common switch for all 3 of those kickers. Contact loose in the leaf? More cleaning? Doesn't look like your gap is too wide.
#11 2 years ago
Bingo. After seeing your picture of the yellow-red wire and what switch it went to I cleaned the large contacts again and adjusted the switch to make even more contact and that was it.
Not sure if it was the extra cleaning or if that switch was just a hair open when closed but it’s working great now.
Thanks again Paul for pictures and advice.
Danny
#12 2 years ago
I've had pop bumpers get weak and I clean and clean those contacts, and eventually, the pops perk up again. This must have been similar.
Glad you got it figured out, Danny - I love that game!
#13 2 years ago
The little things are everything. Thanks Paul, it’s such a fun game.
Can’t walk by it without playing 3 balls.
Space Coast Pinball
This page was printed from https://pinside.com/pinball/forum/topic/fast-draw-weak-kick-outs-and-outhole and we tried optimising it for printing. Some page elements may have been deliberately hidden.
