Starting to fix up the Far Out I got last week. Here is my short list:
- Simple Green the crap out of the cabinet. It has a major case of the yellows!
- Strip/Clean/Wax the PF. The dirt is really ground in to the PF. I've already gone the naptha route with limited results. Tested some Novus 2 in a spot. No change. Dont want to push the issue because I like having paint on the PF.
- Rebuild the toasty left pop bumper. This was the cause of my tech woes. Coil and kit ordered from PBR. I've never done a rebuild with the stopper in the a$$ end of the coil so any tips here would be appreciated.
- Seal the BG (Done). It has some damage. I'm seriously thinking about touching it up via the airbrush method. I bought some colored LED's to see if that would make it passable.
- Replace all bulbs with the 6mm retro LED's from Comet. Ordered.
- Cut out and replace mushroomed shooter and replace. (removed and ordered)
- Replace center pop cap. I broke it. I always break these. Only broke one this time. WINNER!
- Install new coin door lock. I had to drill the old one. Did it at home so I could keep the millions in quarters. Millions = 1 quarter this time.
