I have a Williams Fan-Tas-Tic, just bought and set up. Right away noticed no backbox lighting, but hit credit button anyway, game re-set and played as it should to the best of my knowledge, even played 1 + 2 + 3 + 4 player games and all worked, playfield lighting is working. So investigated backbox lighting, found blown 15a fuse at very top of fuse block, yellow/red wire on both sides of fuse. Replaced fuse, hit credit button and immediately blow #3 15a fuse in block, blk/yell on one side - two black wires on other side. Then I replace #3 fuse but leave #1 out, game resets and plays again. I then remove all bulbs from backbox just to see what happens, same results. Checked jones plugs all OK, no visual signs of issues or burnt smells. So any ideas on where I should start looking? Any help would be greatly appreciated, THANK YOU
