I have a Family Guy machine and a problem.
When the ball goes into the TV scoop, the switch won't activate.
I have replaced the with with a good one. Have made sure that the wire arm is getting pressed by the ball. Tested it (hundreds of times) in switch test and it all checks out fine.
BUT, when i actually want it to work in practice, in a game, it will not register at all. I have had the assembly off and checked it all out and it works fine and as expected. It's as if the ball isn't pressing the switch when the assy is installed (but I know it is because i have had my head inside the machine to check when a ball goes in). I am totally stuck and up against it time wise.
Does any one have any ideas what i can check next?
