(Topic ID: 222734)
Family Guy and the trouble with Stewie
By Rascal-911
  • 7 posts
  • 7 Pinsiders participating
  • Latest reply 2 years ago by dgoett
#1 3 years ago
I looked through the other threads but didn't see anyone having issues with Stewie. Basically I just got this pin and Stewie doesn't rotate or move at all. I did basic quick checks to see if the wiring was in place and harnesses were firmly plugged on the little stepper motor control board. Just wondering if there are any know issues with Stewie motor or the control board. I also tried to active the motor from the diagnostics but it is just like it doesn't have power.
I am guessing this would also apply for Shrek as well. Any thoughts?
#2 3 years ago
Mine came not plugged in from the factory but it looks like you already checked that.
#3 3 years ago
There's also a 2 pin connector for the stewie motor in the playfield wiring harness under the backbox that can cause issues.
#4 3 years ago
Look at page 87 of the manual. Did the set screw on the shaft back out?
#5 3 years ago
It unplugs itself easily during movement or working on the playfield. Just make sure the molex is tightly plugged together.
#6 3 years ago
Having same issue with mine. I am pretty sure that I am getting power to board but nothing from motor. Anyone know where to purchase a motor?
8 months later
#7 2 years ago
Just had this issue and sanctumwear was spot on.
There's a large 2 pin connector with a black and a red wire that was unplugged. It's right where the playfield harness comes out of the convoluted tubing from the backbox and plugs into the main power wiring harness.
Hope that elaboration helps. Looks like pulling the playfield in and out would easily disconnect those if hung up AT ALL.
