I have a Quicksilver that has been having intermittent display issues. There was a few wires that had verdigris (green gunge oozing out of the wires) and i replaced the wires or connectors if required. I now have an unusual issue as pictured - basically when the displays should be unlit (ie: the first digit should be off), there is a faint digit on there. This is unique to all displays except p4.... when i put a new LED display in any position is exhibits the same symptoms. EG: in P4 it works fine, in any other position, it has the faint digit (see pic of it in p2 position).
I am assuming this is an MPU or MPU connector issue - i replaced some of the connectors on J1 but not all. Any suggestions on where to look/test further?
IMG_20190528_045803_resized_20190528_050104020 (resized).jpgIMG_20190528_045953_resized_20190528_050103805 (resized).jpg
