(Topic ID: 249349)
F4 blows on start up - Skateball
By InfiniteLives
6 days ago
  • 5 posts
  • 3 Pinsiders participating
  • Latest reply 5 days ago by InfiniteLives
#1 6 days ago
Hey guys
Was playing skateball and all of a sudden everything goes dead(flippers) gi still on.
Open her up and F4 is blown. Replaced it just to see what would happen and it blows pretty much the moment the power is turned on.
Played hundred games easily without this issue.
Is it likely a failed diode on a coil ?
Where should I start trouble shooting ?
Unplugged the sdb plugs and blows instantly on power up as well
Pulled under playfield fuse and it still blows.
All EOS are gapped correctly. Playfield fuse is not blown.
Might be something on the rectifier board that went bad is what I'm thinking now
Thanks !
#2 6 days ago
Looks like bridge rectifier 3 could be bad. You can check this with a meter, set to diode check.
#3 6 days ago
Quoted from chad:
Thanks, this happened on my lunch break, I am back at work. I will check when I get home. That seems to be a good place to start, thanks!
#4 5 days ago
Definitely check the Bridge. If blown replace it with a higher voltage/Amps bridge as they are cheap.
#5 5 days ago
definitely the bridge rectifier
gonna see if i can find the part number for the beefier one to replace the original e-00602-0003 with.
probably not too hard to find on here, gonna start searching right meow
€ 3.95
Multigame
$ 7.00
Third Coast Pinball
Displays
PinballSolutions.eu
$ 16.00
Yorktown Parts and Equip
$ 14.50
PinballElectronics.com
Third Coast Pinball
$ 99.99
$ 10.50
The MOD Couple
