Hi guys,
Having a strange issue I've never seen before with most of the solenoids on a F14 and am coming to you wise techs of Pinside with an ask for assistance.
Issue: 03A 05A 07A 10 12 13 Solenoids aren't firing in game or in test. (I circled them in the manual picture below)
Steps taken:
Tested fuses
Tested switches
Tested power at solenoids (there is)
Manually fired solenoids by jumping non banded side of coil to ground.
I've had issues like this before but it's always been a blown fuse or an issue where a wire fell off and the circuit was disconnected. I posted on the Facebook help group and got nothing.
I guess I'm hung up because I don't know the circuitry of everything on the playfield. Should I be checking continuity through the harness? The multiple relay boards are throwing me off a little bit, I just wish there was a schematic for the playfield so I can see how everything is laid out. What's my next step here? Thank you so much in advance.
