(Topic ID: 163235)
F14 Tomcat Burning up a Coil
By Major-Havoc
7 years ago
#1 7 years ago
I have a f14 Tomcat that has me stumped. It keeps burning up the right front flipper coil. I think the guy over fused the flipper board. I replaced the bridge rectifier and a burned trace on the flipper board. All the flipper work great and are strong. But after a few games the RF coil gets real hot and the plunger will stick. All the flipper parts are new. Could the yellow capacitor on the flipper bracket cause this? It's a very simple circuit. No transistors.
#2 7 years ago
Is your EOS switch properly adjusted?
#3 7 years ago
Yes
#4 7 years ago
No diodes on the flipper coils, correct? Correct number coil? Check the coil with your ohmmeter- it may have shorted turns from overheating, reducing the resistance and increasing the current. Compare to known good coil.
Check voltages to make sure they are correct. Not sure how you could get too much voltage but check to make sure.
You can run without the yellow cap, it's there to reduce contact arcing, but I can't see it causing the problem.
Don C
#5 7 years ago
Don all the coils are new. I've replaced this coil twice. This is a new issue and just started happening. All the flipper coils have diodes and are the correct coils. I assume its overheating. But why is it the only coil overheating? All the flippers are running off the same circuit to a point. Voltage supplied directly by the flipper board. And ground through the flipper leaf switches to the coils.
#6 7 years ago
I guess Ill go back and replace the coil and re adjust to EOS switch. Only thing I can think of is it must be off. Not much else I the circuit. It doesn't help that his wife can't play pinball and is relentlessly on the flippers. I cringe watching.
#7 7 years ago
Yes, this is baffling. Thanks for posting the schematic.
I am going to suggest more diagnostics. I am going to assume you confirmed all wire colors in connectors, and they are the correct wires in the correct spots on the connectors. If adjusting the EOS does not help, here are some ideas:
My crackpot theory is that you have a sneak path to ground, fairly high resistance, that heats the coil continuously but is not sufficient to pull in or hold the flipper. I suspect it's in the wiring unique to the right flipper with the coil that overheats, from the coil thru two connectors to the cabinet flipper switch blade for that coil.
Meter method:
Game off: Remove the Blk-Yel wire from one right flipper and the Blu-Vio wire from the other right flipper. Meter between the end of the Blk-Yel wire just removed to ground. Should be very high ohms, like Megohms. Press flipper button and it should drop to near zero. Now meter from the end of the Blu-Vio wire to the same ground. Again, should be very high resistance. If there is a difference between the two, then current may be sneaking to ground somewhere along the wiring from the coil thru the cabinet flipper buttons to ground, probably thru the flipper button capacitors or dirt with metal particles in it built up on the switch insulators.
No meter method:
1. Try removing the capacitors on the cabinet flipper buttons (if they are there). If leaky, they could create a current path through the coils but with the flipper button open. Maybe enough current flows to heat the coil but no enough to pull the coil in. Also, if the cabinet flipper switches and their little bakelite spacers are covered in the typical black dirt, clean that up in case that is leaking current. See if problem persists.
2. Again along the leaking current theory, disconnect the (Blk-Yel or BluVio, whichever is the right front one) ground side wire of the coil that heats up (at the coil terminal), and disconnect the wire running from connector at the point where it is soldered to the cabinet flipper switch blade (eliminates all cabinet wiring and connectors 8J3 and 7J1 between the coil to the actual switch contact). Then run a jumper wire from the coil direct to the switch blade. This eliminates all wiring not common to the upper switch. See if problem persists.
Don C.
#8 7 years ago
It certainly sounds like the EOS switch not opening fully when the flipper is 'up'. Remember there are 2 switches on the flipper bracket. One should open, that's the high power to the flipper which would then just leave the hold power. The other switch should close and that's the one on the switch matrix which the game uses for triggering lane change etc.
Can you throw here a few pictures of the wiring and switches? Sometimes a second set of eyes provides that "D'oh moment"...
Mark
#9 7 years ago
The more I look, the more I see. More ideas:
F14 is the transition game to parallel wound coils from serial wound. Clay's guide for System 11 has a very good section on this.
What were the symptoms when the flipper originally went bad? How long had it worked correctly, how did you notice the problem?
This schematic you posted is for parallel wound coils, so it is correct. In the schematic, when the EOS is closed, both coils are energized when the cabinet button is pushed. When the EOS opens, the power coil has no path to ground, and only the hold coil is energized. A leaky EOS switch capacitor or Hold coil diode would run current through the power coil even when the EOS is open, causing extra heating. You can temporarily disconnect the cap to check.
From Clay's Guide:
FL23/600-30/2600: series wound, "standard" flipper strength, and used on games High Speed to Millionaire only. Requires one flipper diode. Same strength as FL11630.
FL11630: parallel wound, "standard" flipper strength, as used on nearly all system 11 games. Requires two flipper diodes. Same strength as FL23/600-30/2600.
What if the ones you are installing are the series wound? Not sure what would happen if you had a series coil in a parallel circuit (unlikely because you said that you got new ones), but the game may have been miswired for a long time, but the first coil somehow survived. Check the wiring against Clay's guide and the schematic. Which lug has the thick or thin wire and how they are connected are critical.
If everything is right, then you can still try my ideas about the wiring between the coil and the flipper switch in my earlier email.
So, Mark has the best idea so far, take some photos and let us puzzle over it.
Don C
#10 7 years ago
As a new tomcat owner - i'm not the most versed on this machine yet - but i can contribute this:
If you EOS is TRULY not opening - i'd be apt to think you'd pop a fuse on the flipper power board within a handful of average length games (at least i did).
#11 7 years ago
Replaced the coil and EOS. Increased the gap just a hair over 1/8" and played the crap out of it. Coil never got hot. Stayed cool. put many games on it and worked the flippers hard. So far so good. Looking at the old EOS. It had good gap but appeared to have debris between the contacts. Possibly allowing arcing or contact.
#12 7 years ago
Ah-ha!!!
Congrats, hope it is solved.
Don C
#13 7 years ago
Well what was worse is they over fused it. So it burned a trace completely off the flipper board. It burned up the header and connector on the MPU for the flipper ground. It also burned the trace on the mpu going to the Relay. So it was fun to fix. And the fact I haven't got a phone call yet its fixed.
$ 39.99
Fort Lauderdale, FL
$ 19.99
$ 170.00
Displays
Digipinball Shop
$ 2.50
$ 54.99
$ 5.00
Metal-Mods
$ 1.00
Pinball Alley
$ 69.00
Pinball Pimp
$ 65.00
arcade-cabinets.com
2,900
Cedar Rapids, IA
$ 12.50
RoyGBev Pinball
Flashinstinct
$ 18.00
2,100
Rancho Cucamonga, CA
5,000 (Firm)
Vandalia, OH
$ 18.95
$ 36.95
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/f14-tomcat-burning-up-a-coil and we tried optimising it for printing. Some page elements may have been deliberately hidden.
