(Topic ID: 195336)
F14 Flasher troubleshooting
By Toyguy
6 years ago
  • 16 posts
  • 3 Pinsiders participating
  • Latest reply 6 years ago by GRUMPY
#1 6 years ago
I've got a couple flashers out. Number 3 on the back panel is out but the paired number 3 on the playfield works, as does the #3 solenoid, so I believe I can rule out the driver board and assume this one to be a bulb/socket issue. Number 4 is out in both locations. Solenoid 4 is a spare so I can't test the electromagnetic device. Can I perform a typical "ground the transistor" test as I would to test a solenoid, stopping the test on Flasher 4 then briefly grounding the tab?
#2 6 years ago
If they're burned out, that test wouldn't be helpful. I would replace the flasher (new or swap a known working lamp) in the easiest to reach socket for #4. If it lights, you found the problem. If not, then you can dig deeper.
Don't over look the flash lamp warming resistors on the under playfield boards. Many have cold solder our even break off completely.
You can see the broken filament in a bad flasher. A bad flasher will also be electrically open when you put a meter across the case and nipple.
#3 6 years ago
Quoted from Toyguy:
Yes you can. On a flasher you don't have to be brief as the pair of flasher bulbs will not melt like a coil will.
#4 6 years ago
Thanks guys. I should have mentioned that the resistor board is a new one and I did put a new bulb in the #4 socket nearest the player but it remains dark.
#5 6 years ago
Grounding the tab on Q24 does nothing. If I'm reading the schematic correctly I should have Solenoid B+ on the bulb all the time and the driver circuit just provides ground, so I ought to be able to meter for around 35V, right? Also, if I ground the socket tab directly, the bulb should light, verifying the bulb, socket and power.
Where do I go from there? The schematic doesn't seem to show these flashers very well. I gather from the table on the front cover there's a connection to the diode board. Is that a likely next step?
#6 6 years ago
Quoted from Toyguy:
Yes and no, Yes it's B+ @ 32 volts dc but this is switched voltage between the A side and the C side. Default is the A side for the coils. So you need to put it in solenoid test for the A/C select and then you should see a pulsing voltage on the orange wire on the bulb socket. Then the voltage goes thru the bulb to the 5 ohm resistor on the resistor board and then to the diode board and then to the CPU board and ground at the TIP.
#7 6 years ago
So no progress yet. I do seem to have voltage at the socket, which makes sense as the voltage feed is just a short jumper from the #5 socket. With that in mind, I started tracing wiring. I have good connectivity on the control wire down to the diode board at B4. I don't seem to be able to continuity check past the diode however. Measurement across the diode is the same as the other diodes on that board.
Any other thoughts on how to go about troubleshooting this?
#8 6 years ago
Quoted from Toyguy:
Read some of this and do some more testing and tell us if you run into more problems.
https://pinside.com/pinball/forum/topic/f14-flashers-not-working/page/3#post-3044898
#9 6 years ago
So I tried a number of the troubleshooting steps in the other thread but everything looks good. I have continuity from the banded side of the diode to the Q24 tab. I have good connectivity from the playfield #4 socket to the unbanded side of the diode. The diode meters just like all the others. Q24 is new. Now, when I put it in Flasher 4 test and ground the Q24 tab to the GND test point on the MPU, I immediately start to get a noticeable hum. It sounds like if I held it there, something would blow.
I am now wondering if there isn't a short in the lamp on the back of the playfield. I'm think what I might do next is to split the 2 control wires at the playfield socket, find the one that connects to the resistor board and attach only that one.
Any other thoughts?
#10 6 years ago
Lets see a pic of the new flasher board.
#11 6 years ago
Here's the flasher 4 board:
Here's the back side of another new one so you can see the traces.
One thing I did differently was splitting the two ground wires to both sides as the holes were a little small. I can't see that this matters as the trace is fully connected across both.
#12 6 years ago
Some new info...
I disconnected both white/yellow wires from the lower playfield #4 flasher. I identified which of the two went to the driver board and jumpered it to the socket. Put it in test mode and the flasher worked.
I metered the second white/yellow wire down to the molex at the bottom of the playfield where it goes back to the rear lamps. With the lead disconnected, no continuity between the lead and the orange voltage wire. With the lead jumpered to the socket, good continuity, so I think the main playfield wiring is good.
Metering the orange and white/yellow pins on the other side of the molex also shows continuity but now Ieed to try and get that darned bulb out of there to see it the continuity opens when it's removed.
My game is early enough that it does not have the PC board for those lamps. It's all point to point so pulling the playfield may be unavoidable.
#13 6 years ago
Quoted from Toyguy:
This is fine.
Quoted from Toyguy:
Yes.
Quoted from Toyguy:
I wonder if the bulb filament is shorted in the bulb, this could cause the other bulb to not light as there would be b+ on both sides of the good bulb. I had assumed that you had already changed both bulbs before posting, that's what I get for assuming.
#14 6 years ago
Problem identified!
Guess I'm ordering a socket
Many thanks also to whomever originally posted a comment somewhere about replacing lamps from the back of the cabinet through the vent grille. That worked like a champ for replacing the #3 bulb which now works great.
#15 6 years ago
On a side note, anyone able to grab a photo of the cable clamping and routing behind the playfield, with it on the prop bar? I'm pretty sure mine is mis-routed and may have contributed to pulling that socket apart.
#16 6 years ago
So the socket is shorted keeping both bulbs from lighting. Nice find.
$ 18.00
$ 39.99
5,000 (Firm)
Vandalia, OH
$ 1.00
Pinball Alley
$ 65.00
arcade-cabinets.com
Fort Lauderdale, FL
$ 69.00
Pinball Pimp
$ 12.50
RoyGBev Pinball
$ 18.95
$ 65.00
$ 5.00
Metal-Mods
$ 36.95
$ 19.99
Pinball Invasion
This page was printed from https://pinside.com/pinball/forum/topic/f14-flasher-troubleshooting and we tried optimising it for printing. Some page elements may have been deliberately hidden.
