(Topic ID: 299814)
F14 blowing q49 constantly
By RandyW
2 years ago
  • 3 posts
  • 2 Pinsiders participating
  • Latest reply 2 years ago by RandyW
#1 2 years ago
I have an F14 that for the life of me, I cannot figure out why it keeps blowing Q49 on the SDB. When it does, any switch on column 2, activates all of the switches. I have tested each switch individually and they work fine, when I replace the transistor. Each diode tests good, all are in the correct orientation.
The pin has had substantial work underneath the playfield previously... but I cannot find a cause for this. I can put it in switch test and they work all day long. Start playing a game and usually within a couple minutes, the game will reset and the transistor is blown again. I've tried to see if it is some other switch, but it never seems to happen under the same circumstances twice. I'm thinking the problem must be further upstream on the board.
Has anyone run into this?
#2 2 years ago
I would check the lane change switches next to the eos switches. See if the eos coil voltage is getting on the switch matrix. Also, if you have an early run of f14 their are 2 flashers on the top of playing surface behind the tomcat targets. A bulletin came out to remove these flashers as these would short against the stand up targets over time.
Your problem is not on cpu board most likely the playfield as that transistor is a first line of defense for high incoming voltage.
#3 2 years ago
Quoted from pinballplusMN:
I would check the lane change switches next to the eos switches..
You were absolutely correct!! Thank you very much, that one has been driving me insane!!
$ 170.00
Displays
Digipinball Shop
5,000 (Firm)
Vandalia, OH
Pinball Invasion
$ 19.99
$ 65.00
arcade-cabinets.com
$ 18.95
$ 5.00
Metal-Mods
$ 1.00
Pinball Alley
$ 69.00
Pinball Pimp
$ 18.00
$ 39.99
$ 12.50
RoyGBev Pinball
$ 36.95
Fort Lauderdale, FL
This page was printed from https://pinside.com/pinball/forum/topic/f14-blowing-q49-constantly and we tried optimising it for printing. Some page elements may have been deliberately hidden.
