Quoted from drsfmd:
While I’ve got the board out, would you replace the other BRs as preventative medicine? Or is BR2 the only problem child?
No need to fix what is not broken. There is no reason to.
Good on you for acquiring the right part. I've seen many BR hacks where amateurs would hack in a lugged BR using amateur methods.
While it's out....check C2 to ensure it's not leaking. This happens frequently, affecting the 12VDC circuit.
Check J101 and J114. If shiny and bright, move on. Otherwise, if you are up to it, replace them. Rationale: those are the power in/out connectors. They are at the top of the list for causing resets.
I wouldn't mess with any of the big 15,000uf caps. They are hard for the typical hobbyist to remove without damaging the board. And again, don't fix what is not broken.
Chris Hibler - CARGPB #31
http://ChrisHiblerPinball.com/contact
