(Topic ID: 274256)
F-14 Tomcat: Upper flipper problems
By Brewchap
8 days ago
  • 5 posts
  • 1 Pinsider participating
  • Latest reply 7 days ago by Brewchap
#1 8 days ago
The upper flippers will not work with the flipper buttons. So to test them out I grounded out the flipper with a jumper from ground. I get a little bit of movement but not enough to hit the EOL switches. They are very weak when grounded, but you might get a slight twitch using the flippers. I re-pinned the ground connector going to the flipper board and I also tried a difference flipper board. Nothing has made an improvement.
Oh and I can move the flippers with no resistance at all. And cleaned the flipper switches.
Im out of ideas unless I got coil problems, Guess that I better test them.
#2 7 days ago
I removed the yellow capacitor and re-soldered the wires. That didn't help.
Testing the coils, I found that on both rear coils that I would read 7 ohms on one lug and 176 ohms on the other. Testing the front coils, I get 5 ohms on both lugs on both coils.
I think that there is something going on with the rear coils from the reading that I got. Now to figure out what that is....
#3 7 days ago
Quoted from Brewchap:
I found that I still have the same reading with the wires removed. I also verified that I have 75 volts on the banded side of the lug.
#4 7 days ago
I found the specification for the coil and they are correct.
Primary winding (power) ~6.2 ohms (no diode)
Secondary winding (hold) ~160 ohms (no diode)
I also found out that I was grounding the wrong lug getting a weak result. Grounding the correct lug, I get strong flippers.
#5 7 days ago
Well, I'm not sure what I did other than repeatedly hit the flippers, but is it now working.
$ 19.99
$ 50.00
$ 15.75
Cabinet Parts
Tilted Pinball
$ 85.95
Gweem's Mods
$ 54.99
$ 9.00
$ 17.00
2,000
Topeka, KS
