I was working on a dim bulb on the right sling shot assembly on f-14. This is near the right flipper.
I noticed the metal housing was very loose. So I was pushing on it. Suddenly that light went off along with several others. Including the light beside it and both sling shot lights on the left side.
Additionally the middle target light (the one that is green) also went out and also all the target lights that are down inside the target.
All the insert lights work. I checked fuse and were all ok. Any ideas what else to look at? Could it be resistor?
I checked again and were the problem started. Which is the right kicker assembly sling shot light housing. I don t see any disconnected wires. Appears no power is greeting to them. What else can I ch k?
