Hi Pinside,
I recently picked up a F-14 Tomcat. When I got it home and set up, I noticed that the player 4 display is missing the "f" segment. Its consistent across the one display, and the other segments are nice and bright.
I tried removing the cable and connections from the display and reseating them back on, but it didn't change anything. Later tonight I will try to switch the connections for display 3 and 4 and see if the symptom switches to 3 and if 4 works perfectly. Until then, any advice on what I should be looking at fix the missing f segments? Maybe corrosion on a pin responsible for the f? maybe a poor ribbon cable? I'm pretty new to pinball machines so any help is appreciated.
