Hey guys, I'm new here and new to being the owner of my first pinball machine! I have primarily been into collecting video arcade games but I've always wanted a pinball to add to my collection. I recently acquired an F-14 Tomcat. The only info I received from the previous owner was that "it works but just doesn't show the score"
I have searched all the forums I can find but I figured since I feel like I'm in over my head here I would plead for advice from all you more knowledgeable folks.
Right now the status of the machine is:
1: No display at all (none of the four displays have any output or even a faint glow).
2: The diagnostic led WAS flashing 5 times until I replaced the IC in "U41" this afternoon. Now it just continuously flashes.
3: The batteries were corroded at some point but the previous owner had removed them. I attempted to neutralize every bit of corrosion with a scrub of 50/50 vinegar and water.
4: When the machine is booted it makes 5 sounds like a bomb dropping then a single "ding". It doesn't go into attract mode on its own. I can only get it to coin up and play if I press the "sw1" cpu test button on the motherboard. At that point it lights up and I can add a coin and play. Otherwise it just sits with a few main lights on.
At this point my main questions are:
A: What do you suggest I try next?
B: How do I start checking voltages everywhere? Specifically power to display or even overall health of main power supply.
C: Should my "diagnostic" led be continuously flashing? I've only read about what 1-11 flashes mean. When it was 5 flashes I replaced u41. The +5 and blanking lights are solid.
D: Does the game NEED batteries to function? I removed the battery box because of corrosion. I'll add a new one later.
Thank you all so much for any advice!
