I'm following Vid's guide on getting tech help, so first the cut and paste part:
Name of game, manufacturer and year: Williams F-14 Tomcat, '87
Did it ever work in your Possession?: Yes. Worked with no problems for about a year and a half. After the first incident, it went another 11 months before blowing again (more about that below).
Did You Run the Diagnostics?: Not an option in this case. Heard the sound of sizzling electronics and shut it off.
Where did the game come from?: Some guy in Baltimore.
Have needed MODS been done?: Lighting is LED except for flashers. I've added a few LED strip lights as well.
Are any aftermarket boards installed?: No.
What was the last service you performed?: Had board worked on a year ago.
Battery Corrosion: No. External battery pack.
LED or Incandescent lighting?: LED except flashers
Blown fuses: Flipper fuse blew
Smell: Yep.
Obvious Past Work Performed:Details below
Do you have a Volt Meter?: Yes, but I'm only competent at using continuity/diode mode
Can you solder?: Mechanical things, yes. Boards I stay away from.
Last spring, I was playing f-14 tomcat, and I noticed something weird was going on with the diverter; after a confused minute or two, smoke was coming out of the game! I turned it off, and the lower diverter coil was totally smoked, plus the sick smell of hot electronics was coming from the back box.
Like a dummy, I halfass diagnosed the problem and had somebody replace the transistor which controls the lower diverter. Naturally I replaced the coil as well. Long story short, it didn't fix the problem.
I then sent the CPU board to Coin-op Cauldron for proper repair. I have Clive's email and will post after this description. Got the board back, turned on the game, and ZAP. Driver transistor blew out yet again.
Then I took the whole game to a guy more local to me (about an hour and a half away, here in MA). He eventually figured out that the diode on the replacement diverter coil was bad. Another $200 poorer, I now had a working F-14 again.
Fast forward to a couple weeks ago. My friend came over to play by himself (he helped buy the game in the first place and has his own key). Now, I wasn't here to see what happened, but he said the game was acting weird and then the flipper board blew its fuse. Like an idiot (or just not expecting the exact same problem to come up AGAIN), I turned on the game to test things out in diagnostics (after replacing the fuse). It took only seconds to hear the sickening sound of things frying on the board. Sure enough, driver transistor melted down, and under the playfield, the lower diverter coil was totally burnt.
I know about the Williams service bulletin regarding the diverter gate binding, and it was already addressed before I bought the game. I sent the board back to the guy here in MA - a guy who is NO DUMMY; he used to work at MIT - and he seems at a loss to explain what the hell is going on. At this point I'm out yet another $100 for repairs and don't know whether to try to keep the game running or try to sell/trade it. But I'd feel shady selling or trading without full disclosure, at which point it seems like most people would pass.
I'd really like to get to the bottom of this, if only for the peace of mind.
