(Topic ID: 301989)
F-14 Tomcat 1 Player Display Not Working After Move
By Phesson
2 years ago
  • 12 posts
  • 7 Pinsiders participating
  • Latest reply 2 years ago by slochar
#1 2 years ago
I have a Williams System 11 F-14 Tomcat. All my displays were 100% when I purchased it but after transporting and setup the first player display is blank. The other 3 are working fine. I reseated the connectors on the display board and MPU but had no change.
After looking through the forum I see post about missing segments, scrambled text but nothing about one blank display. Last week it was bright and no segments were dim or missing. I understand the chips that control the alpha numeric displays control both player 1 and 2. If they were bad the player 2 display would be bad too, yes?
Where should I look next for the solution?
Thank you.
#2 2 years ago
If it is an original display, it's time may have passed and gone bad. You could try reseating thd connectors on the display panel.
#3 2 years ago
#4 2 years ago
Quoted from JT-Pinball:
Switch player two display to player 1. If it works the player 1 glass is bad or that display board has a break somewhere. If it doesn’t work try using the cable from the working display.
Thanks JT
#5 2 years ago
Yeah man. Good luck. I love F-14.
#6 2 years ago
They are soldered ( all 4 ) to the board and connectors are different. Will not work.
#7 2 years ago
Quoted from chad:
Chad, I guess the next step is to check the connectors again. Will update tomorrow.
#8 2 years ago
bad glass. Seen it happen so many times. Not an ic issue if one display completely dark
#9 2 years ago
Chances are your player 1 display gassed out. Will need to replace it, if you can find one. I purchased a new one from PBR. you have to reuse the PCB the display is soldered to though.
#10 2 years ago
#11 2 years ago
No luck last night. Looks like a new display board is the way to go.
Now to decide on the red display or the blue.
Thank you all for your help.
#12 2 years ago
Get white and the filters that way you can switch if you don't like.
$ 36.95
$ 18.95
$ 170.00
Displays
Digipinball Shop
$ 19.99
$ 1.00
Pinball Alley
$ 54.99
$ 69.00
Pinball Pimp
$ 44.99
Pinball Shark
Fort Lauderdale, FL
$ 65.00
arcade-cabinets.com
$ 18.00
Pinball Invasion
5,000 (Firm)
Vandalia, OH
$ 39.99
$ 5.00
Metal-Mods
This page was printed from https://pinside.com/pinball/forum/topic/f-14-tomcat-1-player-display-not-working-after-move and we tried optimising it for printing. Some page elements may have been deliberately hidden.
