My first post and I am looking for input. I have combed these boards like a parasite for the last month and a half as I brought my F-14 Tomcat back from the dead after being stored for ten years. I’m nearing the finish line with one last issue to resolve, but I am stumped on this one.
Flasher 06C and the knocker don’t work. I realize they are related. I have tested what I could, but have had no luck resolving the issue. Following are the things I have done. (I learned it all from these boards including temporarily replacing fuses with thermal breakers. Thank you.)
All other flashers – and everything else – works
Checked fuses first by removing and checking continuity – all of them
Tested continuity from 06C’s flasher board (blk/blu) to diode board. Good
Tested continuity from diode board (gry/blu) to MPU. Good
Tested Q23 transistor. Good. Common on center leg .582/.507 Common on outer legs null
Q19 reading .2 and change on one side so I replaced it. No improvement
Tested knocker coil and diode. Good (this is a new coil)
Tested flasher board resisters. Good – (resistors are new since old ones were broken)
Verified good soldering – no cracked or loose solder
Started diagnostic and jumped from the ground strap to Q23 tab and knocker fired
Started diagnostic and jumped from the ground strap to Q23 tab and 06C bulbs lit up solid - not flashing
Started diagnostic and jumped ground and driver on the flasher board and again the bulbs lit up solid – not flashing
Disconnected from J11 and J12 on MPU and tested diode on diode board. Good. .5something and null (not sure this was correct procedure)
I’ve considered SR6 or SR7, but I don’t know how to test them and I have no replacements on hand. They seem to serve multiple circuits though so if one were bad I would expect to have more issues. Wiring diagrams and schematics are not my forte, but my eyes are blurry from staring at them in the manual. If anyone has a suggestion as to what the issue might be or where I go next I would appreciate the input. Thanks.
