(Topic ID: 227467)
F-14 Switch Matrix Help - Fixed again...I hope
By GLSP3022
6 months ago
  • 18 posts
  • 4 Pinsiders participating
  • Latest reply 5 months ago by GLSP3022
#1 6 months ago
Hello all.
I have an F14 that I am shopping out/repairing for a friend. The game has developed a switch matrix issue.
The game was working perfectly for days, I shut it off this evening to make dinner, come back an hour later power it on and this issue has surfaced.
Using the switch edge test, I have determined rows 1 thru 5 all register the switch in row 6.
Rows 6 7 8 all register correctly. See pic.
I disconnected the switch matrix connectors and used the jumper/diode test on the board and get the same results.
These early system 11 games are not my strong point. Ideas or suggestions what is failing?
I am comfortable with board work.
Thank you.
#2 6 months ago
Anyone?
After looking over the schematics, I'm guessing an issue in either u30 or u39. They're just upstream. Because the lower 3 rows work fine, it shouldn't be an issue with the 8 driving transistors.
#3 6 months ago
I have had these chips fail and produce these symptoms.
For the price with shipping, buy a couple extras.
#4 6 months ago
First thing to check with J-8 and J-10 removed and power on, all pins (except the key pin) of J-10 should be high if using a probe or close to 5 volts if using a DMM. Then check with a probe all pins of J-8, they should be high with a low pulse.
Have you been working around the flippers with the power on? Could you have shorted the EOS switch to the lane change switch?
#5 6 months ago
Quoted from GRUMPY:
This is the weird part. I've rebuilt just about everything under the hood, but the game was playing well. At power up last night, everything went to crap with the switches.
I kinda wish I knew what happened, would make this a but easier to understand.
Quoted from johnnycruzr:
I ordered a 10 pack of these. Socket them and try that first.
#6 6 months ago
Quoted from GRUMPY:
I'll check this out and report back.
#7 6 months ago
Might also check resistor networks at position SRC6, SR11 or SR14.
#8 6 months ago
Socketed and replaced U30 and U39. Luckily I already had several of these chips in stock. Switches are working fine now.
What caused it? I have no idea. I did a thorough search under the entire playfield and found nothing unusual or close to touching.
UPDATE: This morning after power up, the switch matrix is going crazy again. The balls in the trough are causing other switches to think they're closed. I did change all the diodes on the trough switches, no luck.
I'm totally confused on this one.
Game is good then goes to crap after it sits.
Not sure if U30 and U39 got toasted again or not.
#9 6 months ago
I had the game playing 100% last night.
On power up today, matrix is freaking out again. What the heck??
#10 6 months ago
Quoted from wayout440:
#11 6 months ago
Those failing can cause havoc with the chips? The one does appear burnt.
I will check that out.
#12 6 months ago
Quoted from GLSP3022:
Without looking, they are most likely pull up resistors. Yes, they can play havoc with the signals if one or more resistor in the pack has failed.
#13 6 months ago
Thanks for the info.
I ordered some to replace all the networks in that area. We'll see what that does.
#14 6 months ago
Did you ever test the chips? The burn marks on SR-11 and SR-10 shows that the EOS switches have been shorted or are still shorting to the lane change switches. If you are smoking the Nand chips then the resistor packs are not the cause but an effect.
#15 5 months ago
Quoted from GRUMPY:
Hi Grumpy, the burns marks were there for awhile based off of pics I had taken. Since, the flippers have been rebuilt. Ive checked those EOS switches many times again. Tonight I am replacing the resistor arrays and trying new chips again. Wish me luck
#16 5 months ago
I changed out the resistor arrays at SR9, SR11, SR14 per the advice of wayout440. I put new chips into U30 and U39. Grumpy i am half tempted to follow your advice and check the last set of chips to see if they are indeed bad or if it was the resistor packs.
So again, the game is playing 100%. But I've been here before. I'm not out of the woods yet. Thank you all for your advice, I may need more soon.
#17 5 months ago
Even if the resistor packs were bad, there would not have been any damage to the chips. There only would have been crazy switch matrix issues.
#18 5 months ago
So far so good! Tomcat was left on this evening for several hours. I played a few games randomly throughout the night and it's still acting normally. I'm still not ready to call this resolved just yet.
$ 50.00
$ 221.00
Cabinet Parts
Tilted Pinball
