This F-14 is new to me. I believe I have gotten all issues fixed except 2:
1. flasher 2 is not working, bad cement resistors located
2. The game resets when you get balls locked in both left and right center ejects. Credits are also added during game play
In switch level test all switches in column 3 green/orange will cycle through all switches in their row on the display when activated and held. Both the left and right center ejects are in this column. Unplugged the switch matrix connectors from the board and tested with jumper wire at the board connectors with the same results.
In switch edge test each switch in column 3 shows up as the switch in the same row, but in column 8 (20=60, 21=61, 22=62, 23=63) Switch 24 is the exception. It shows up as the switch in the same row but in column 7: 56. I am guessing this is because switch 64 is not used.
This leads me to believe the problem is with the board not the playfield wiring.
How do I narrow down and find the bad component?
I have a dmm and possibly access to an oscilloscope.
