(Topic ID: 172113)
F-14 resto
By heni1977
7 years ago
There are 339 posts in this topic. You are on page 4 of 7.
#151 6 years ago
Yes! Back at it!!
FA2BF4F0-AB7A-45E3-A58C-DB987AF03BC4 (resized).jpegFA2BF4F0-AB7A-45E3-A58C-DB987AF03BC4 (resized).jpeg
#152 6 years ago
Just DO IT!
#153 6 years ago
Got some time so tearing under side down. Thought y’all would like to see a nice fix with a wood screw.
97BD2643-0CBA-48D2-8F5B-49BBB8947142 (resized).jpeg97BD2643-0CBA-48D2-8F5B-49BBB8947142 (resized).jpeg
4E82E0BB-BEDE-4437-BED6-F488E84F3739 (resized).jpeg4E82E0BB-BEDE-4437-BED6-F488E84F3739 (resized).jpeg
#154 6 years ago
This one jumped out at me too!!!!
#155 6 years ago
Quoted from heni1977:
Its a very pretty screw though...
#156 6 years ago
Looks like someone took out there lifes anger on that resistor board .
#157 6 years ago
Good use of some old colored zip ties. Keeps the switch stacks together.
65A85E78-7FD6-487A-829B-94D0AA2AC185 (resized).jpeg65A85E78-7FD6-487A-829B-94D0AA2AC185 (resized).jpeg
#158 6 years ago
Ideas on getting these rails out of PF?
25F43A18-73CE-438D-870F-0E232FDA2CE2 (resized).jpeg25F43A18-73CE-438D-870F-0E232FDA2CE2 (resized).jpeg
49841097-458D-4FB9-946C-666339F8FF65 (resized).jpeg49841097-458D-4FB9-946C-666339F8FF65 (resized).jpeg
33285827-C823-4CD2-A4A3-D55C01F1D9D5 (resized).jpeg33285827-C823-4CD2-A4A3-D55C01F1D9D5 (resized).jpeg
#159 6 years ago
I have plastic pry tools that work pretty good. Here is a pic of what they look like, stick a rag underneath so you dont dent or scratch the playfield. I think they sell them at harbour frieght but have not used theirs.
Screenshot_20180221-190351 (resized).pngScreenshot_20180221-190351 (resized).png
#160 6 years ago
I would put a wood block under the rail, then put a blue bar on top of the wood block followed by another wood block on top of the blue bar. Then lightly pry a little on each side until it works itself up and out.
#161 6 years ago
Best thing to use is a pair of channel locks. The rounded head has the best leverage. Just out a cloth underneath and work it up side to side. Nothing I've found works better.
#162 6 years ago
Joe,
One games i have done, I have taken the rails off and then took them to one of the cabinet shops here in town and had brand new ones made. Your redoing everything on this, might as well do it all, lol. Ill give you a few places to try if you want
1 month later
#163 6 years ago
So it’s been a little over a month since I last posted. Been busy with work and honey do list.
So I have time today and I am going to put another coat of clear on PF.
A couple pics for a update.
I cleaned paint booth up again just to make sure I don’t get any contamination.
Wiring harness is off and just a few things left on old PF.
79A5FF6D-1CD2-4D52-8919-845DCCB08229 (resized).jpeg79A5FF6D-1CD2-4D52-8919-845DCCB08229 (resized).jpeg
9F0CC4BC-A1DA-4251-9DF1-B8E8F19683CC (resized).jpeg9F0CC4BC-A1DA-4251-9DF1-B8E8F19683CC (resized).jpeg
9502F791-8294-4E40-A869-AC6591796F53 (resized).jpeg9502F791-8294-4E40-A869-AC6591796F53 (resized).jpeg
#164 6 years ago
You ever thought about sanding down the back of the playfield while you have the chance ?
#165 6 years ago
Never really thought about it. Guess if I needed to I could after the clear was good and dry. Like 30 to 45 days dry.
Still did not clean enough in booth damn!
#166 6 years ago
Quoted from SUPERBEE:
The one I am clear coating now is a NOS that I purchased. The other one will be sanded down and gotten ready for a hard top when they come out. Hopefully!!!
#167 6 years ago
Quoted from GRUMPY:
You should check the 4 pin connector before the relay and fuse and see if you have 30 AC on the pair of white/blue wires. This should be powered any time the power is on. Then test the fuse. If both of these are good then remove the relay and look for cracked solder joints on the bottom of the board
Working on getting the beacons working today. Then later will do some fill in on the pf.
Getting wierd readings though.
#168 6 years ago
Good to see some movement here.
Life sure gets in the way of fun!
#169 6 years ago
So I am getting 25 to 27 ac volts on the white and blue wires. Is this enough?
#170 6 years ago
Here is bottom of relay. Looks good to me.
#171 6 years ago
When in beacon test does the relay click or not?
#172 6 years ago
Yes I believe it was. Will check later had to go to my dads and work on his Harley.
#173 6 years ago
I was too lazy to take pictures and document my restoration. Now I am kicking my self. Next time I might do a time lapse vid.
#174 6 years ago
Yes relay is ticking. Could the wiring be incorrect?
#175 6 years ago
So in your last pic, separate this connector and with the power off test the side without the yellow wires. Pick one of the wht/bl wires and check for continuity to the fuse holder until you find the correct one. Now that you have the wht/bl wire that comes from the fuse attach one of the meter leads to it, turn on the power. Now check for power with the other meter lead on the relay. One of the 2 wht/bl wires should show power any time the machine is on (note the terminal label). If this is good then put it in solenoid test and check the other relay wht/bl wire, when the relay clicks it should show power (note the terminal label).
#176 6 years ago
So the side that says coil is showing 21 to 23v
And GND is showing 65v both of these not in test.
In test it shows
Coil side shows the same in test. Pic for reference and to make sure I am testing correctly?
#177 6 years ago
This is .023 volts. This is just noise, consider this as zero volts.
Quoted from heni1977:And GND is showing 65v both of these not in test.
This sounds good.
Quoted from heni1977:In test it shows
Would the same be .023 volts or the 65 volts?
#178 6 years ago
Not in test
Coil shows .023 GND shows .065
In test
Coil shows .023 GND fluctuates between.065 and .067
#179 6 years ago
Not in test
In test
Something not adding up here, replace the fuse and retest.
#180 6 years ago
Ok, went back to beginning. Pulled and checked fuse, fuse tested good but replaced just in case. Retesting wht/blu wires getting .047
In test it bounces between .029 and .030
#181 6 years ago
Let's start at the beginning, just off the transformer. A pair of wht/red wires 30.60 volts AC any time power is on. Now the next connector in the back box a pair of wht/red with a pair wht/ blue wire spliced together 30.60 volts AC any time power is on. Up to the relay, clip on to the fuse with one lead and the other on the coil terminal of the relay board 30.73 volts AC any time the power is on. To test the output of the relay you need to move the test lead from the coil terminal to the grd. terminal on the relay board, you need to disconnect the connector going to the motor and place in coil test and lock it on solenoid 16. You will get a pulsing output on your meter if the relay is working. I didn't get a pic of this as I only have two hands. Try this and let us know what you find.
#182 6 years ago
Quoted from dudah:
Any plans to Retrobrite the "clear" dome?
Someone in this thread tried it and he says it does not work on clear pastics. Worst, it can make them milky.
https://groups.google.com/forum/#!topic/rec.games.pinball/UhHpNoLcEAM
#183 6 years ago
Once I get my beacons going I will decide if I want to go with a different clear dome. I like to think that the yellowed dome kind of gives it some nostalgia. Where would I be able to find a clear one? And not the white one that marco sells.
#184 6 years ago
Damm my pics are backwards again!
#185 6 years ago
Haha, no worries. Thanks for being so patient with me!!!!
#186 6 years ago
Coming from the transformer
#187 6 years ago
Connection at back box
#188 6 years ago
Ok, I get noise or zero volts at the test for the clip on the fuse and the coil.
#189 6 years ago
Go back to this connector and retest with a test lead on each of the wht/bl wires.
#191 6 years ago
Zero.
I also noticed this though it was stuck behind the harness. It hangs into the cab.
#192 6 years ago
https://www.pinballinc.com/index.php?route=product/product&product_id=63&search=Clear+dome
I bought all three domes from pinball Inc. They are perfect.
#193 6 years ago
Ok. Jumpered that harness to the large black connector and now I get the 30v at the wht/bl 4 pin at relay. Tested the clip on fuse and to coil on relay board and get zero.
Went and looked at pf harness and it looked like it doubled back. So I jumpered it.
#194 6 years ago
I will check them out cletus Thanks!
#195 6 years ago
I'm not following this, can you show me a pic.
#196 6 years ago
0A4C5A74-7A06-401A-940E-557C143D6EAA (resized).jpeg0A4C5A74-7A06-401A-940E-557C143D6EAA (resized).jpeg
#197 6 years ago
That doesn't look like a good idea.
#198 6 years ago
I was kinda worried!!!! It was only temporary to see if I got the 30v to the relay. Which I did but nothing on the coil side or gnd side of relay board.
#199 6 years ago
I think that is a spare connector which never had anything connected to it. I would like to recheck the 4 pin connector 2 wht/bl 1 red and 1 brn wire. Check the wht/bl wires on the female side.
#200 6 years ago
Quoted from GRUMPY:
This is a reply i never want from Grumpy !
$ 19.99
$ 69.00
Pinball Pimp
$ 39.99
$ 18.95
$ 54.99
Rancho Cucamonga, CA
Fort Lauderdale, FL
$ 1.00
Pinball Alley
$ 65.00
arcade-cabinets.com
$ 2.50
5,000 (Firm)
Vandalia, OH
$ 18.00
$ 5.00
Metal-Mods
2,900
Cedar Rapids, IA
$ 36.95
Flashinstinct
This page was printed from https://pinside.com/pinball/forum/topic/f-14-resto/page/4 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
