I'm getting random tilts on my F-14. I've read the posts about the resistor networks causing this problem. I'm running an 11B board so the caps are separate from the resistor network and all the resistors test ok. Wiring at the plumb bob, ball roll & playfield tilt switches is good. What should I check next?
Thanks.
