(Topic ID: 211216)
F-14, now with new weird error message!
By CadillacMusic
1 year ago
  • 7 posts
  • 3 Pinsiders participating
  • Latest reply 1 year ago by tonyhoff1
#1 1 year ago
So I already put a post on here about this F-14, which was insisting the 6116 memory (u25) was bad. I changed the output chip below the processor and it went back to working fine. Today, it has decided that once every dozen boots or so, it has a u10 error. This doesn't stop the game, which then boots and goes on working. But it's not right, and someone would like to buy this machine. There's clearly something pooping on the data or address line, and doing it very rarely. How does one determine what chip is at fault?
#2 1 year ago
might be a power supply issue. cpu tries to access u10 (a pia?) before the power is stable enough and reads a port back wrong.
you can disconnect whatever U10(assuming PIA and if possible) connects to and see if that makes it go away.
#3 1 year ago
I read on pinwiki that sometimes having an old socket on your PROM or processor will make this happen. So I replaced the socket on U27. So far so good, but I'm not calling it okay until at least Tuesday.
#4 1 year ago
So the game ran fine for 3 days. Then yesterday, when I powered it on, it just hung. Nothing on the display. Turning it off and on again fixed it, but I need to fix the problem. Anyone have any ideas at all?
#5 1 year ago
I had the same problem with a taxi. And my end result was power supply board. I rebuilt it and the game never did it again. Just a thought.
#6 1 year ago
Hmm. Must admit I haven't touched the power supply. Worth a shot. Did you use a particular rebuild kit, or just replace all the caps?
#7 1 year ago
I replaced the caps and the regulator on the heat sink.
Yorktown Parts and Equip
$ 221.00
Cabinet Parts
Tilted Pinball
$ 79.95
Gweem's Mods
$ 19.99
€ 3.70
$ 50.00
$ 14.00
$ 5.00
Metal-Mods
