I am having an issue with the left flipper on my F-14 and am stumped.
If you play a game, the lower left flipper coil eventually gets weak and hot (melted one coil).
If you hold the flipper in the up position, the lower left coil makes a "buzz" sound, gets hot, and eventually blows the fuse on the flipper power supply board.
I have:
Checked, double checked, triple checked the wiring (referencing wiring diagrams in manual).
Replaced ALL diodes on the switches and coils.
Replaced all switches except for the normally open EOS switches on the lower flippers.
Replaced all flipper coils (FL-11630 lower and FL-11722 uppers)
Replaced ALL diodes again, including the ones on the new coils.
Rechecked all wiring again....and again....and again.
Gone through about 4 bags of Radio Shack fuses while testing
The normally open EOS switches on the lower flippers register during the switch test when closed.
All other switches in the matrix of these switches work properly, these switches also appear to be the only link to the CPU board the flippers have.
I'm starting to think I may have a bad flipper power supply board. Is there a way to test these?
This is my only system 11 game, so I can't swap the board from another game.
Any help/ideas are appriciated!
