(Topic ID: 115279)
F-14 Displays. Difference between early and late production.
By MrArt2u
9 years ago
  • 26 posts
  • 10 Pinsiders participating
  • Latest reply 3 years ago by Crash
#1 9 years ago
Hello all,
I'm trying to troubleshoot an Early Production F-14 Tomcat with two bad displays (player 2 and 4). I have a spare display board from a later production game that I was hoping to plug in for testing. Is the difference between these two display boards only the size and the way they mount in to the speaker panel? Can I safely plug in and use my later production displays for testing(and possible fabricate a new mounting system)?
Has anyone posted how to troubleshoot and repair these boards? (besides shotgunning in new displays, which I understand is usually what goes out.) I also have a Cyclone in the wings with player 3 and 4 out, I'd like to attempt to repair before I replace.
Thanks in advance,
Art.
#2 9 years ago
Yeah, I think they are just different sizes.
#3 9 years ago
Good to know. The last thing I want is to blow up my good display panel and end up with THREE broken display boards.
I still want to find more information on troubleshooting these display boards. Any tips?
#4 9 years ago
Pin and compatibility wise they are exactly the same.
The early production ones has added 555 sockets to light the speaker panel area so they are physically larger in size.
#5 9 years ago
And the larger size display panel on the early production F-14 models is what costs $350.00 to upgrade to a Pinscore PS-11415-F display.The $350.00 price tag is entirely due to low production number. It is only used on F-14 and Millionaire machines. Where as the later run F-14 models can be fitted with a $199.00 orange Pinscore PS-11610 display (other colors available if you want to pay extra). Also, Rottendog makes one for $150.00. Unless you want to unsolder and turn all the pin headers around and re solder them, you need the Pinscore PS-11415-F display on an early run F14.
Post edited by StylesBitchly: updated info
#6 9 years ago
Quoted from StylesBitchly:
And the larger size display panel on the early production F-14 models is what costs $350.00 to upgrade to a Pinscore PS-11415-F display if you want to. Where as the later run F-14 models can be fitted with a $160.00 Pinscore PS-11610 display in you choice of colors! Unless you want to unsolder and turn all the pin headers around and re solder them. Then it may fit the early run F-14. The $350.00 price tag is entirely due to low production number. It is only used on F-14 and Millionaire machines.
Is there a documented process anywhere for this? I have an Millionaire with that setup and well... don't want it, lol.
I may have the same problem on F-14 and probably don't want that either.
**edit*
Went to check my F-14. version 554 #99457. . Someone put a "new" one in there that seems like it was working (they said in masking tape one of the panels doesn't work). One day I might try it when i get all the board back in and the wires hooked up. By far my worst machine.
#7 9 years ago
At the moment, the pinwiki site doesn't have a whole lot of information on getting down and dirty with the displays. This should be useful though.....
http://techniek.flipperwinkel.nl/wms11/index3.htm#display
I guess you tried the usual things like pulling the cables off and putting them back on again, or giving them a "wiggle"? The displays do go bad, but worth checking the above link first
#8 9 years ago
Were you able to fit the smaller, later production display board in your early production F-14? Is that where the unsoldering and turning the pin headers around comes in? I haven't been in there yet to investigate, I'm hoping to find the time tomorrow night.
#9 9 years ago
Display boards are fairly easy to troubleshoot.
Refering to the display schematic.
U5, U1, U6, U2, U13, U12 and U9 are simply drivers for the displays - converts low voltage to high voltage to drive them. If you have a signal going in, it wil drive the corresponding segment.
U13 = player 1 & 2 display (extra characters), U12 = player 1 & 2 display (numeric characters only), U9 = player 3 & 4 display. U13, U12 and U9 are driven by non-inverting buffers for the inputs to the drivers (voltage in = voltage out).
U5, U1, U6 and U2 basically control which display is being updated.
U3, U4 ,U7, U8 are a TTL logic buffered NOR gate (datasheet here: https://www.fairchildsemi.com/datasheets/CD/CD4011BC.pdf ) NOR gate truth table here: http://www.ee.surrey.ac.uk/Projects/CAL/digital-logic/gatesfunc/index.html#norgate
Basically if you have both inputs low you will get a high output, so for U8, pin 12 and 13 have to be low to geta high output on pin 11.
So measure voltage at each input and see if the output corresponds - if not bad chip (make sure you check the voltage supply is present on the IC's as well).
You also need to check to make sure you have high voltage for the displays as well: R10, R12, R14 and R17 should have +90v while R11, R13, R15 and R16 should have -100v.
Hopefully that makes some sense.
#10 9 years ago
No, I haven't done this. There is a thread here on Pinside all about it and that was the solution for fitting the less expensive PS-11610 display into an early run F14.
The problem is that the less expensive PS-11610 display's wiring connectors hit the H channel below the translite. The only way to fit it without setting the display LED's farther back from the speaker grill window, is to reverse the wire connectors.
I am afraid to drop the money on a display only to void the warranty and find out the soldering is not achievable. Some solder points are quite small.
#11 9 years ago
LongJohns
Are the U chips driving my pinscore as well. I am having intermittent LED segments on Player 1 and 2 windows. Or is this a problem with the Pinscore display board?
#12 9 years ago
LongJones
Sorry not familiar with the pinscore display.
The U chips I mentioned above are located on the original scoreboard - if you replaced the OEM board with a pinscore one, then you don't have those chips (they would be using some other driver chips for LED's). I would guess you have a problem with the pinscore unit.
#13 9 years ago
There is a thread here on Pinside all about fitting the less expensive PS-11610 display into an early run F14.
https://pinside.com/pinball/forum/topic/early-model-f-14-display-question
#14 9 years ago
Thanks for that link. I don't know why it didn't come up when I searched. It answered a bunch of questions, and even introduced me to the problem of the replacement displays being so far back from the speaker panel.
I'm still hoping to troubleshoot my original. The missing displays definitely have voltage so, next I'll follow LongJohn's notes above to see if it's a chip. I understand the glass goes bad too so I'll probably be looking for some of those at some point.
I was able to get some games in on this new-to-me F-14 and, other than the displays, wow, it plays great! Can't wait to get it all dialed in.
#15 9 years ago
I would just buy the Rottendog display (your choice of colors for $150.00). Big Daddy has them. People have mounted these using a simple home made bracket and the display only sits back from the speaker panel glass about 3/4". 1/2" if you move a capacitor to the back side of display. Not a problem according to one guy I talked to. FYI, the $350.00 Pinscore for early F14 also sits back from the window about 1/4".
#16 9 years ago
Glad your having better luck than me.
So far this early run F14 I bought is a money pit! Everything is a big PITA and no simple fixes. I'll be pissed if I have to buy another display. It was the pinscore display that made me buy it. Then it takes a shit 2 months into ownership and I can't get any answers.
Didn't PinScore Displays come with a 5 year warranty, or are you outside of that time frame?
Pretty sure Marco covers the Displays even if you're not the original purchaser as long as you can verify their age being under 5 years. There should be a date stamp on them somewhere.
Best of luck !!
Pin - K
#17 9 years ago
I have contacted Pinscore via email yesterday and waiting for reply. I don't know if it was purchased from Marco
#18 9 years ago
Well, I did call Marco and they said that the warranty is not transferable. Original owner only.
#19 9 years ago
Hey Look!
A cheaper option than Pinscore for early run F14. And probably better quality!
XPin XP-WMS11415-F
$239.00
http://www.xpinpinball.com/shop/product/xp-wms11415-f
#20 9 years ago
I saw those at the Banning Expo! Met the guy behind X-pin (Brett?) and we talked about them. For an added fee he can special make it in different colors too. He didn't have any with him (he brought one, sold one right away) but he offered to ship me one at a show price. It was early in the weekend and I told him I'd have to think about it, well, fast forward to getting on the freeway as we're driving away and me kicking myself for not taking him up on the offer!
I do like X-pin's quality so that's still an option. Gotta make sure this game is a keeper for us so getting the rest of the gameplay 100% comes before new displays.
Thanks for the heads up!
Art
2 years later
#21 7 years ago
I know it's late in posting this, but my Pinscore problems with digit segments not illuminating intermittently was caused by power source putting out low voltage on the 5 volt rail.
1 year later
#22 5 years ago
Was this on the power board?
1 year later
#23 3 years ago
Quoted from MrArt2u:
I'd like to know more about this as well. There's a big price difference between the two models X-Pin offers ($199 for late vs. $289 for early). I don't know what version my machine is, but it does have all 3 sockets present for the light domes. Without visually checking I would guess it's an early game.
#24 3 years ago
It appears to be a late model. The number of connectors I have matches the headers on the less expensive board. The mounting holes on the smaller late production board also line up with my speaker panel.
#25 3 years ago
I was wrong, the additional connector on the early X-Pin display isn't populated. I have the clear flasher domes in the back, a clear center topper dome, individual 44 sockets for the inserts, a 4 digit serial number that starts with 9, and a 554 model number.
Now my question is, can I order the less expensive late model display from X-Pin and flip the headers to the other side of the board to ensure a flush fit? Here is my speaker panel. I don't have the manual to check the original display's part number. I sold the original 7 years ago and no longer have the photos.
#26 3 years ago
Bump. Has anyone installed a late display in an early F-14?
$ 1.00
Pinball Alley
$ 65.00
5,000 (Firm)
Vandalia, OH
$ 18.00
2,100
Rancho Cucamonga, CA
$ 2.50
$ 36.95
Flashinstinct
$ 65.00
arcade-cabinets.com
$ 5.00
Metal-Mods
$ 18.95
2,900
Cedar Rapids, IA
$ 69.00
Pinball Pimp
Fort Lauderdale, FL
$ 170.00
Displays
Digipinball Shop
$ 39.99
$ 19.99
This page was printed from https://pinside.com/pinball/forum/topic/f-14-displays-difference-between-early-and-late-production and we tried optimising it for printing. Some page elements may have been deliberately hidden.
