Trying to fix up a F-14 CPU to go in a High Speed. Clay's guide indicates it should work, the original board took a pretty heavy alkaline bath and just isn't economically repairable.
It came in as a bit of a project, and I've fixed everything but this sound issue. Added the missing 4 pin connector at 1J15.
The high speed background sound board is 100% tested good with another working HS CPU. As is the ribbon cable, and the little 4 pin connector that jumps the 2 boards together.
In sound test, the game makes no sounds. Even at max volume, I don't hear any faint sounds.
In music test, the game makes all the music just fine.
ROMs are good. I tried 2 sets, and tested them both in the other HS MPU.
I tried changing out the procs for the hell of it, they work fine. U24 is definitely running, and I see activity on all the address and data lines.
Lots of socketed ICs on this board. That's good for troubleshooting, yet also bad for troubleshooting, because you have to question the quality of previous rework.
I've buzzed out the sockets and replaced a few that looked crappy.
Both 1458 op amps were socketed, so I tried 2 good ones, and it made no difference.
Putting my finger on U1 makes the hum I'd expect it to make, I believe the amp is working fine.
I put in Leon's sound test ROM. It makes the heartbeat sound as expected, and the PIA outputs dance in rhythm as expected, but the sound test button does not cause it to reset. This points at the RAM. I replaced that socket, as it was a big dodgy, and buzzed it out. Tested the 5116 in the socket, and the neoloch tester says it's fine.
So, I'm trying to figure out where to go next.
U6, U7, U8 and U9 are all socketed. I have tested U6-U8 with my IC tester, and tried a different PIA in U9. I also buzzed out all 4 sockets and everything is well.
I took a break for awhile, will get back to it later. Any ideas?
