(Topic ID: 235348)
External sub early solid states?
By lowbeau67
  • 9 posts
  • 7 Pinsiders participating
  • Latest reply 1 year ago by Lostcause
#1 3 years ago
Ive read a ton of posts on external subs and think what i want to do is cool but
just wanted to throw it out there and see if im right. I have a SBM and a F2K
that i want to hook up to an extra sub that i have. So all i have to do is run
off each bottom speaker of each cabinet with my speaker wire into the inline
connections on the back of the sub and all is good? thx for any insight.
#2 3 years ago
Quoted from lowbeau67:
What kind of subwoofer? (make and model) Does it have line inputs, high level (speaker level) inputs, or both?
#3 3 years ago
Here's how I do it. You can add/remove/switch games very easy. The subs I have let you hook up 2 at the same time. Depends on your sub and inputs.
#4 3 years ago
Quoted from Travish:
What method are you using to connect them and how does that change the impedance/load at the sound board?
#5 3 years ago
The polks are designed for 2 inputs. Vid has a pretty detailed post here somewhere.
#6 3 years ago
Early solid state games sound great with a powered external sub, and even better if you can stick a small tweeter someplace. Early Bally games have a heat vent on the front of the head pedestal that is a good spot. I have this on my centaur and Medusa, and also just did black hole and haunted house.
I just use alligator clips connected to speaker wire to tap off the cabinet speaker, very easy and reversible.
#7 3 years ago
Thx for the replies. I have a sony 10 inch or 8 inch Polk i can use with the high level inputs. Glad to know i can do this. Thx
1 year later
#8 1 year ago
Quoted from PNBLWZD:
What tweeter do you use - I'm thinking i could put one into the head pedestal of my medusa.
#9 1 year ago
Quoted from Grefla:
You could add a cheap piezo tweeter without worrying about using a crossover, just connect up with you normal speaker.
Like these https://www.esr.co.uk/electronics/loudspeakers8.htm
Cabinet Parts
Wire-Bot
$ 12.00
Third Coast Pinball
8,000 (Firm)
Santa Ana, CA
$ 11.00
Third Coast Pinball
