(Topic ID: 140468)
External 12 v power supply for DMD?
By SkillshotExhibit
7 years ago
  • 15 posts
  • 10 Pinsiders participating
  • Latest reply 7 years ago by Blindseer
#1 7 years ago
Hi All,
Has anyone installed an external 12 volt power supply to a Sigma color dmd?
If you've created your own, Id love to know how to do it.
Or if you know someone who is selling such a thing, please let me know.
#2 7 years ago
Why not just use a Happ video game supply for about $25?
#3 7 years ago
You may want to check with Randy @ ColorDMD about the Voltage ColorDMD uses.
I could be wrong but I'm pretty sure ColorDMD uses 5VDC and not 12VDC (or possibly both ??).
Let us know.
Kim
#4 7 years ago
Quoted from Pin_-_K:
Let us know.
Kim
Both, according to the website:
In contrast to existing high-voltage plasma displays, the ColorDMD uses the low voltage 5V and 12V outputs from a power driver board. A keyed 4-pin power cable is provided for simple connection between the ColorDMD driver board and the existing power driver board. An expansion connector on the power cable provides support for other existing boards and devices.
#5 7 years ago
I wonder if you could use a cheapy 12/5v pc power supply like this:
amazon.com link »
#6 7 years ago
Quoted from KenH:
amazon.com link »
We do use a supply similar to that for bench testing our displays. We cut the connector off and replace it with a 4-pin 0.156 KK molex connector. I have not tried to integrate one within a game.
#7 7 years ago
Quoted from KenH:
amazon.com link »
I don't know how much current the color dmd pulls, but i had trouble getting one of those to power up a sys11 board. Then again that board is full of power hungry ics.
I got a cheapy mean well 12v/5v psu on the bench now. Works well, not sure how reliable it would be long term with extended power on time, i see chinese no name brand caps in it.
#8 7 years ago
Quoted from barakandl:
12V is less than 1A and depends on backlight brightness.
5V is under 100mA and mainly used to drive the USB port.
#9 7 years ago
Quoted from Dmod:
So the Happ supply should be more than adequate. Specs at +5VDC @15A max and +12VDC @2A max. You could probably use an "El cheapo" supply, but most of those are less than an amp and might not work, or possibly get too hot, IMO.
#10 7 years ago
Quoted from wayout440:
I would use this. $25.00 is too much for a $400.00 Color DMD?!?
#11 7 years ago
Thanks all! I just wanted to mention that I love my Color DMDs ( I have three), they are awesome!
Im grasping at straws to come up with a fix for my TAF resetting problems, this is what Ive tried so far-
Ive replaced the varisistor. I have a color dmd on my TAF and I have resetting issues from time to time. Ive been told that a resetting issue could be caused by a bad bridge rectifier and capacitor on the WPC driver board. I sent the board into a professional board repair person and was told that my board was fine.
I have my TAF and three other machines plugged into a power conditioner, TAF has always had resetting issues and the others have not.
I also purchased a daughterboard from Kahr daugherboard for resetting issues (http://www.kahr.us/daughterboard.html). I have the daughterboard plugged into all of my machines and they work just fine. When I plug the daughterboard into the TAF, only half the lights work and the dmd either does not work or looks all garbled up. I contacted Kahr and described the symptoms and he told me to check the board in the other machines, it works just fine, so he suspects that I have a bad bridge rectifier and capacitor on my driver board.
Should I just have the driver board re-tested ? My driver board is a Rottendog, the CPU is an original, I just had it tested also, CPU was replaced due to battery acid leak.
UGH.
#12 7 years ago
Its not easy to test for a failing bridge rectifier or capacitor so I'm not sure about what you were told by the board repair person. The problem can also be caused by a poor solder joint or cracked traces.
You can try reflowing the solder connections for the 5v bridge and cap. It that doesn't resolve it, replace the components.
The ColorDMD mainly draws power from the 12V supply and would not trigger a reset on the 5V logic. However if there's any doubt, unplug the ColorDMD and start flipping all flippers at the same time. It should still trigger the reset.
#13 7 years ago
Quoted from KenH:
amazon.com link »
This exact thing works perfectly on color DMD installed in games. I have personally used it. You need the 12v and 5v off it. Just out onto a connector you can get from say Pinballlife.
#14 7 years ago
Quoted from Dmod:
Try this and if the problem is still there go through the reset troubleshooting procedure at pinwiki.
http://www.pinwiki.com/wiki/index.php?title=Williams_WPC#Game_resets
Quoted from Dmod:
If you have the proper equipment it is not at all difficult to check for a failing bridge or capacitor.
1 month later
#15 7 years ago
Quoted from SkillshotExhibit:
UGH.
I went through a similar issue with my TZ I bought Kahr.us board in my machine when I bought it because I was having reset issues and everything worked fine for about a month. One day the game froze and the DMD would just show lines. When I reset the game it would continue to do this. I sent my power driver boards and my cpu boards out for repair, got them back and still had the issues.
I reseated the cables and the game worked for a day then it came back. I started to disconnect boards and firing the game up till the issue would go away. The issue stopped when I unplugged the sound card so I used this as an excuse to buy a pinsound card before I send out my sound card for repair. I made all new ribbon cables for my machine as well.
Fast forward to yesterday, I install the pinsound card and while it was unpacking the zip files the machine crashed again. I started removing the dmd, sound card, the flipper board, and the gi lights were still freaking out. So I unhook the Kahr.US board and the game started to work again. I played 1 game then turned it off and rebooted and it still didnt crash. So I put the board back in and within 20 seconds the game crashed.
I think something went wrong in the kahr.us board to cause this, and I love the Kahr.us board too. So I emailed Rob and he is sending me a replacement and ill send my daughter board back.
So far 2 days of turning the machine on and off and playing with no problems. I also tested LitZ to give the game a workout and no reset issues or crashes.
Were there other issues beyond the daughter board? The sound to the right speaker was getting crackled and louder as the game went on (weird because they are in parallel) but since I replaced the sound card all speakers sound great.
I hope this helps and thank you Rob for replacing my daughter board, you rock!
$ 58.00
Toys/Add-ons
$ 1,159.00
Flipper parts
Gweem's Mods
Sound/Speakers
$ 29.00
Pinball Photos LLC
Decorations
This page was printed from https://pinside.com/pinball/forum/topic/external-12-v-power-supply-for-dmd and we tried optimising it for printing. Some page elements may have been deliberately hidden.
