(Topic ID: 297074)
Excalibur (gtb sys 80b) dead pop bumper
By chuckwurt
2 years ago
  • 7 posts
  • 5 Pinsiders participating
  • Latest reply 2 years ago by chuckwurt
#1 2 years ago
Just got an Excalibur and the pop bumper doesn’t work.
It has the separate pop bumper board like most gtbs.
I have swapped in another board, but still doesn’t work. I’m not entirely sure the other pop bumper board works though.
Can you help me figure out if it’s the board?
I have verified there is power at the coil.
The switch has continuity.
The switch doesn’t register in test, but I’m not sure that switch is part of the switch test.
Any ideas??
Thanks!!
Erik
#2 2 years ago
Are you getting good 5v and GND at the board?
#3 2 years ago
Quoted from Cheddar:
That's what I thought when I read the post, especially if he's switched the board and it didn't fix the problem. It's either that or something related to the coil (The coil itself or the plunger).
#4 2 years ago
You need good +5 volts and ground at the connector on the pop bumper driver board. Sometimes the connector header pins develop bad solder joints.
#5 2 years ago
One I worked on, the GND (far right) pin on the pop bumper board connector was measuring 1.2 volts to cabinet ground. Fixed a broken wire going to the reset board and that brought the GND pin down to reading zero volts. This may not be the only possibity though.  (resized).png (resized).png
#6 2 years ago
Thanks for the ideas guys. I’ll check on all this stuff and report back.
#7 2 years ago
Sent the mpu and driver out for bulletproofing so I can completely rule those out of the equation. I’ll look at it again once those come back and I can repin some connectors.
$ 83.00
PinballReplacementParts
$ 5.95
The Pinball Scientist
Great pinball charity
Pinball Edu
