Here is an copy from the guide:
Before Turning the Game On: Check the Coil Resistance.
A very good idea for any unknown game just purchased is to check all the coils' resistance. If the game is new to you, and you have not powered it on, a quick check of coil resistance will tell you a lot about your new game. This takes about one minute and can save you hours of repair and diagnosing work.
Any coil that has locked on (usually due to a short solenoid driver board transistor) will heat up and have a lower total resistance. This happens because the painted enamel insulation on the coil's wire burns, causing the windings to short against each other. This will lower the coil's resistance, causing the coil to get even hotter. Within a minute or so the coil becomes a dead short, and usually blows a fuse.
If the solenoid driver board (SDB) transistor is repaired, and the game is powered on with a dead-shorted coil, this will blow the SDB's same transistor again when the coil is fired by the game for the first time! There is no sense making more work for yourself. So take 60 seconds and check all the coils' resistance BEFORE powering the game on for the first time!
In order to check coil resistance, put your DMM on its lowest resistance setting. Then put the DMM's red and black leads on each coil's lugs. A resistance of 2.5 ohms or greater should be seen. Anything less than 2.5 ohms, and the coil and/or driving transistor may be bad. Now remove the wire from one of the lugs of the coil, and test the coil again. If the resistance is still the same (low), the coil or diode is bad (and also perhaps the driving transistor). If the resistance is higher than 2.5 ohms, the coil is good but the solenoid driver board transistor is shorted and will need to be replaced. Lastly, the coil's 1N4004 diode could be shorted too, giving a false low coil resistance. Cut one diode leg from a coil lug and retest the coil's ohms.
When replacing a coil with a new one, and make sure there is a 1N4004 diode installed across the coil's lugs. Remember when reconnecting the wires to the coi that the power wire (usually two wires or thicker wires) goes to the coil's lug with the BANDED side of the diode attached. The thinner wire is the coil's return path to ground via the SDB.
