Hi everyone,
I just got an Evel Knievel and am not quite sure what to do next in trying to get it to work. I've looked through a lot of other pinside posts that seem to address some of these issues, but really, I'm not really sure what to do next. This is the first game I've gotten that didn't work when I got it, and I'm a bit of a beginner at fixing things of this nature.
The previous owner (less experience fixing machines than even me) had it for 10 years and he never got it to boot up, although he tried. He noticed corrosion on the MPU board from the battery that was there, so he replaced it with a new alltek board, and that's about it. When he turned it on for me, the red 5V LED light on the board stayed on. I repinned some of the J4 connectors after I brought it home, and it booted.
Then I did something stupid: I saw a stray wire next to a chime coil and assumed it cracked off in transport to my house. I hooked it on and booted up the game and got to play! It was 30 seconds of awesome: everything seemed to work fine, but I can't be sure. The game just stopped, and I realized that (a) I shouldn't have connected that wire (I later found the coil to be bad), and (b) Fuse F4 blew. So I unhooked that wire, put a chime coil in my shopping cart, and replaced F4. There is also a new black charred area on the solenoid board that seems to be limited to just stuff very close to the R10 resistor (I am not skilled at reading schematics, but this seems to feed one of the chime coils, so this at least makes sense to me).
Currently, the game boots, I can start a game (only the faulty chime coil unhooked. One other chime coil is disconnected, but the third chime coil is connected), but no solenoids work: not the chimes or flippers or pops or anything). During a game, you can manually touch targets and activate switches and the score will keep track of it. When I do the solenoid test, no solenoids fire. The switch test passes as well.
I made the following measurements at the following test points. I thought I had done these before my stupidity and that all of the measurements were what they were supposed to be, but I can't be sure of what it was before. I realize now I should have been more deliberate about keeping track of stuff like that, but like I said, I'm a bit new at this:
Test Point measurements at (original) rectifier board with all plugs in:
TP1 5.9
TP2 can't get a reading, possibly due to corrosion on the test point itself
TP3 14.2
TP4 6.4
TP5 44.5
Test points at (original) Solenoid board (that has the charred resistor) with all plugs in (except one chime wire pulled out):
TP1 5.1
TP3 5.1
TP5 14.4
TP6 5.1
TP7 5.1
While I've been trying to solve this problem, I've been doing an LED conversion, which I just completed today (I put in a new alltek board along with the LED bulbs). There are some lamp sockets that appear to need to be replaced, but I can't see how this relates.
From what I can tell, these are some things I could do:
--Identify all components on the solenoid board that fried and replace them. Or just replace the board. I've never soldered anything before--maybe I could try replacing stuff and if it goes badly, then panic and get a new board.
--I've read of a playfield solenoid fuse on Ballys that some (all?) EK were produced without. I can't locate this fuse, but all other fuses are intact, even the one on the solenoid board near the high voltage area.
--I don't think the measurements on the rectifier board are correct. I'm not sure how to test individual components on that (or any) board with certainty. Still, I could just replace that board too. Or, I'm wrong and those readings are fine.
--I'll get some practice soldering when the new chime coil arrives. All other coils tested fine.
My questions for you all are:
(1) I don't understand what the confluence of these problems mean. That is, do you experts out there see something about these symptoms that points to just one problem, or many unrelated issues? I get the sense that (with exception to the disconnected coils), that if I could just restore power to one wire feeding the solenoids, the game would work fine. (I've read posts describing a daisy-chaining of the solenoids, and I think I've found that wire, but don't know how to test it.
(2) If you were in my shoes, what would you do to try to solve the problem? I'm willing to solder components, but if you think this is too big a job for someone with my lack of experience, would you just replace the board(s) if you were me? Given these symptoms, am I likely to damage a new board unless I address some other issue?
(3) Is there something I clearly don't understand about diagnosing this that I need to learn?
So I appreciate all of your help, and I apologize for my lack of experience. I don't think I'm an idiot, but I know I have a lot to learn. Thanks for any suggestions.
PS--On a personal note, the posts that I've read on pinside are, for the most part, extremely helpful. This community of people is really (a) knowledgeable, (b) helpful, and (c) very, very kind! I'm very thankful that you all take the time to help others. I also recognize that this post asks about things that already appear in other posts. I started a new topic because I just didn't know if those posts related to these issues. Thanks again for any help.
