Hi guys,
I bought a twister about 7 years ago and am finally getting around to bringing her back to life. I bought it from an operator not working, so ive never seen it running.
The fault im having is when I turn it on, the game boots with DMD working well but the PF insert controlled lamps are hard on (GI is fine) and when I close the coin door the flashers, fans/spinner and controlled lamps stay hard on but the GI switches off.
I can enter service mode via the coin door test buttons and run the tests and make adjustments fine, most PF switched test fine (I haven tested coils yet) although neither flipper buttons or EOS are registering.
When I got the machine it did have the power driver board replaced (by op) with a stern whitestar rev. G. One thing I have noticed is the L204 led is blinking so I dont think im getting a watchdog hand shake from the CPU. (the CPU is in excellent condition with battery corrosion)
I have replaced the ribbon cable with no change.
Really weird fault as the game boots, attract sound/music is fine and test mode hold its settings as it should.
I'm a little stumped on this one so any ideas would be welcomed
Added over 3 years ago:
(the CPU is in excellent condition with NO battery corrosion)
