My Evel Knievel pinball machine stopped working awhile ago. When it was turned on the GI lights would come on, but there was no power up tune and the game would not play. I found that the Self-test LED on the MPU module would only flash 2 times instead of six, which indicates a bad MPU module. The MPU board did have battery acid damage at the bottom when I bought the machine, so I mounted a new battery remotely and the game played fine for years like this. I decided that it was better to buy a new replacement MPU board rather than fix the original. I ordered the Alltek Systems Ultimate MPU board along with the lamp and solenoid driver boards.
I started the repair by installing only the new MPU board and this fixed the startup trouble and allowed me to play the game, but the switched lights did not work. I installed the new lamp driver board and solenoid driver board, but the switched lights on the playfield and backbox still would not light up.
I started checking the bulbs and sockets and didn't find any problems with them. I checked the pins and connectors on the boards and didn't find any corrosion.
The self test LED's on the new boards indicate that they are working. I saw a video on YouTube showing how to check voltages at the test points on the transformer rectifier board. Here is what I found:
T1-.04v dc Should be 5.4v
T2- 233v dc Should be 230v
T3- 15.6v dc Should be 11.3v
T4- 6.9v ac Should be 7.3v
T5- 45.8v dc Should be 43v
You can see that the reading at T1 is very low. Looking at the wiring diagram for the power transformer module shows that the T1 location leads to the J1 Playfield connection #7 which is for the SW. ILL. BUS and also to the J3 Backbox connection #6 also for the SW. ILL. BUS.
Is this the most likely cause of the switched light problem I'm having. If so would it be better to replace the rectifier if it is bad or order a new rectifier board.
The wiring diagram shows 4 rectifiers, but I only see two on the board and one mounted remotely above the board on the side of the backbox.
The photos of the rectifier board shows what I'm talking about, and the wrinkled appearance on the back side has me worried.
