(Topic ID: 209553)
Evel Knievel restore new NOS playfield (finished)9/4/18
By tatman9999
5 years ago
  • 76 posts
  • 23 Pinsiders participating
  • Latest reply 4 years ago by tatman9999
    There are 76 posts in this topic. You are on page 1 of 2.
    #1 5 years ago
    Evel Knievel restore has started. Plans are to restore and clear coat playfield. Restore and clear cabinet. All new switches and targets, new drop targets. Rebuild all coils. May do a overlay but am going to try touch up first and then clear coat. Playfield is not to bad. Got all the Mylar up all ready.
    #2 5 years ago
    Another one of your threads I'll be following! Love Evel!
    #3 5 years ago
    I just got those same drop targets in the mail today. Where did you get the new caps that you show in picture # 1?
    #4 5 years ago
    Quoted from bbhenry2000:
    Sent you a PM
    #5 5 years ago
    Thank you
    #6 5 years ago
    Part are starting to show up.
    #7 5 years ago
    Got play field stripped down.
    #8 5 years ago
    Sanded playfield down. Clear coated the playfield. Applied the decal. Couple inserts are off a little. Will need to clear it then do some touch ups.
    #9 5 years ago
    Couldn't help but notice the "ER" that is on Evel's belt buckle on the original playfield. Could it be the initials of the previous owner?
    #10 5 years ago
    Quoted from thundergod76:
    Not sure but good find. I see the overlay has EK. The old playfield was touched up all over with Mylar over it.
    #11 5 years ago
    All right another tatman restore!
    Favorited!
    #12 5 years ago
    What does the inside of the coin door look like?
    #13 5 years ago
    Wood side rails painted blue. Apron stripped and painted white then cleared.
    #14 5 years ago
    New MPU board came in today. Ordered 2 of them one for the KISS I am restoring also. Also got the Alltec LEd boards
    #15 5 years ago
    Apron is done.
    #16 5 years ago
    Looking great so far!
    #17 5 years ago
    Well thing have changed with Evel Knievel restore. I found a new NOS playfield. So now I am doing a playfield swap. I will be clear coating it first.
    #18 5 years ago
    Little bright pic of it. Would of liked a CPR playfield but not many out there. I like the whites to be bright white.
    #19 5 years ago
    Worked on the cabinet a little today. Clear coated it. Will sand tomorrow and touch up some of the over spray and spots I missed.
    #20 5 years ago
    Quoted from tatman9999:
    Did you clear over the original cabinet?
    Any particular cleanup/prep you did before spraying?
    I have an EK to do, with a new CPR. One day.
    rd
    #21 5 years ago
    Quoted from rotordave:
    rd
    cabinet was pretty nice. I cleaned it bonded small marks. I masked it off and sprayed the white. I used auto clear and cleared it to lock in the colors. I will mask off red and blues and spray them next. then I will clear again. Wish I could find a CPR playfield. I have a NOS new playfield that I plan to clear. I just like the whites better on the CPR.
    #22 5 years ago
    Yeah, the new CPR looks stunning compared to the 40 year old POS that is currently in my EK ...
    rd
    #23 5 years ago
    Doing a EK now,Pinball Pimp cab decals are second to none.CPR is doing Harlem Globetrotters these would look great next to each other
    #24 5 years ago
    What are your plans for the overlay now? I may be interested if you want to part with it.
    #25 5 years ago
    The overlay did not line up on some of the inserts.
    #26 5 years ago
    Worked on the cabinet a little today. Touch up and clear
    #27 5 years ago
    Are you standing between coats of clear on the cabinet? Looks amazing.
    #28 5 years ago
    Quoted from mrm_4:
    Yes I am sanding between coats. Thanks
    #29 5 years ago
    Cabinet has last coat. Will wet sand and buff
    #30 5 years ago
    Got legs on. New side rails. New lock down bar. All new Alltec boards installed.
    #31 5 years ago
    NOS playfield is here and I clear coated it. Looks nice.
    #33 5 years ago
    She's coming together beautifully!
    #34 5 years ago
    I have played EK.
    It always amazes me that when you see a playfield like this ( in the restoration threads) that it seems so much more colorful.
    Perhaps it is because when you are playing it you are more focused on the ball than the background.
    That is some really fine work and it will be an excellent example when it is finished.
    #35 5 years ago
    What red did you use for your cabinet? I don't know if it's just fade or what, but my red looks mixed with an orange or pink or something.it just looks like a goofy color. Also, I'm envious of the Playfield.
    #36 5 years ago
    Did you put any speckle color on the cab? I've heard some people say it should be silver speckle and others say gold speckle.
    My EK cab was repainted (poorly) by the previous owner and I want to redo it with pinball pimp stencils but I wasn't sure what color speckle to use or maybe just not speckle it at all.
    #37 5 years ago
    Looking good !!!
    #38 5 years ago
    Quoted from docquest:
    There is no speckle on mine. I think only the EM Evel Knievel had silver speckles. Mine was poorly touched up. I just touched it up better and cleared it.
    #39 5 years ago
    Pin is at my work. I will check the color of the red tomorrow.
    #40 5 years ago
    The SS version restored I did last year with my awesome stencils had Gold speckles.
    #41 5 years ago
    Quoted from PinballPimp:
    About ready to order up a set of said stinsils this week! Now that I finally got cab tore down on EK I am doing full restoration on. Can’t wait!
    #42 5 years ago
    ??CPR over NOS? The blues on the CPR stuff are off, I'm sure you could have found someone to swap a NOS for a CPR for sure but I don't know why you would.
    #43 5 years ago
    Got playfield together. Have a few switch adjustments to do. Waiting on a new plastic set that I found. All new light sockets and ground wire.waiting on one spinner also.
    #44 5 years ago
    Quoted from paintpins:
    I could not find a CPR playfield.
    #45 5 years ago
    You are making amazing progress. Nice work! Game is going to be beautiful
    #46 5 years ago
    Quoted from pintechev:
    Thanks. Few more things and it will be done. Fire power will be next.
    #47 5 years ago
    Game is Incredible!
    #48 5 years ago
    Stunning
    #49 5 years ago
    Quoted from JT-Pinball:
    Game is Incredible!
    thanks you.
    #50 5 years ago
    Working 100% now. New plastics and it will be done.
    This page was printed from https://pinside.com/pinball/forum/topic/evel-knievel-restore-has-started/page/1 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
