(Topic ID: 353063)
Evel Knievel Restoration #1
By Jjsmooth
4 months ago
  • 32 posts
  • 5 Pinsiders participating
  • Latest reply 3 months ago by pindel
#1 4 months ago
My first EK, so pretty excited to do one. Loved Evel back then (up until the Snake River Shakedown).
This one apparently spent WAY too much time in a smoky bar. Worst case of tar/nicotine nastiness that I've seen. Def wearing gloves to dismantle.
#2 4 months ago
#3 4 months ago
#4 4 months ago
Going to have to replace bottom of cabinet.
Someone was actually successful in cutting out the bottom to steal the coin box.
17100011135042052309039648971301 (resized).jpg17100011135042052309039648971301 (resized).jpg
#5 4 months ago
Lower cabinet stripped of parts
17100015232011571998967061010849 (resized).jpg17100015232011571998967061010849 (resized).jpg
#6 4 months ago
Quoted from Jjsmooth:
It's better than cutting a hole in the playfield. A rock pinball suffered this fate at a college dorm game room years ago.
#7 4 months ago
I believe it. They must have needed beer money.
Cutting 1/2" off the bottom of cabinet to remove lower panel.
17100032641927548316954077066941 (resized).jpg17100032641927548316954077066941 (resized).jpg
#8 4 months ago
I'll replace the bottom with 1/2" plywood.
17100038228843836685708544225043 (resized).jpg17100038228843836685708544225043 (resized).jpg
#9 4 months ago
Bondo and glaze applied and sanded.
Ready for primer/sealer.
17101875226844984142822094591937 (resized).jpg17101875226844984142822094591937 (resized).jpg
#10 4 months ago
2 coats primer applied. I'll send this lightly with #800, and spray base coat.
I'm using base/clear coat on this one.
17101890760475296408624495477140 (resized).jpg17101890760475296408624495477140 (resized).jpg
#11 4 months ago
3 coats of white base applied.
Excited to paint the red and blue, as Im doing metallic on those..as Evel intended.
1710195394083483252379184325042 (resized).jpg1710195394083483252379184325042 (resized).jpg
#12 4 months ago
17103670040883450437761569087466 (resized).jpg17103670040883450437761569087466 (resized).jpg
#13 4 months ago
Nailed the blue color. Love it. Clear applied later.
17104597548584741182271533848301 (resized).jpg17104597548584741182271533848301 (resized).jpg
#14 3 months ago
Complete harness removed and cleaned.
No more cigarette stink.
#15 3 months ago
Display panel stripped of all parts, and painted. I'll be putting all new lamp sockets, common wires, and led displays (Pinitech) in this.
17107126490221255770984044952753 (resized).jpg17107126490221255770984044952753 (resized).jpg
#16 3 months ago
Brand new coin door skin, from Absolute Pinball.
Beautiful
17107967662757274904630173934711 (resized).jpg17107967662757274904630173934711 (resized).jpg
#17 3 months ago
keep up the posts! I am following closely as my Evel will be going under the knife soon. new PF, cabinet paint etc. just because I am OCD
#18 3 months ago
Beautiful
Chris at pinball plating will chrome that skin for 275. Great deal and way to take restoration to the next level. That doesn’t include trim. You could buff the stainless trim for a decent look if you don’t want to pay another 225.00.
#19 3 months ago
Or…..you can go the cheapskate route and sand, polish and buff either an existing skin or a new skin and get results like this.
#20 3 months ago
Playfield has arrived. Apron painted and decals applied (Planetary).
Doing a bit of custom work on the legs, and then apply clearcoat on legs, cabinet, apron.
29ea67e7-4250-4b53-808a-164f6ad80576 (resized).jpg29ea67e7-4250-4b53-808a-164f6ad80576 (resized).jpg
#21 3 months ago
A bit of custom paint for the front legs. I'll use white legs on the back. These will get touch ups in a couple areas before clearcoat.
I'll also continue the red pinstripe across the letters on the cabinet front.
6d3188f6-31de-461e-b0f4-dedfd8988dd7 (resized).jpg6d3188f6-31de-461e-b0f4-dedfd8988dd7 (resized).jpg70fe180b-7158-48b4-954c-6f6c344ebc4e (resized).jpg70fe180b-7158-48b4-954c-6f6c344ebc4e (resized).jpg
#22 3 months ago
Playfield progress today
17112375597922192007565803869259 (resized).jpg17112375597922192007565803869259 (resized).jpg
#23 3 months ago
Up on all four. Just put PF in cabinet to have a look.
Almost ready to reinstall cleaned harness.
17114965812571974760565262408918 (resized).jpg17114965812571974760565262408918 (resized).jpg
#24 3 months ago
17114966584835221324488713479406 (resized).jpg17114966584835221324488713479406 (resized).jpg
#25 3 months ago
Drop unit and apron finished. Top of pf complete.
Ready to reinstall cleaned harness tomorrow,
17123615900645392367801346475546 (resized).jpg17123615900645392367801346475546 (resized).jpg17123616402798161976742490690264 (resized).jpg17123616402798161976742490690264 (resized).jpg
#26 3 months ago
17123616638026721340178340109347 (resized).jpg17123616638026721340178340109347 (resized).jpg
#27 3 months ago
17123617158237784724213347415627 (resized).jpg17123617158237784724213347415627 (resized).jpg
#28 3 months ago
17123618039233450362565394718687 (resized).jpg17123618039233450362565394718687 (resized).jpg
#29 3 months ago
Harness installed, except for spinner switches.
I'll get lower cabinet harness installed, and start putting this back together.
17125360832684248599599985333575 (resized).jpg17125360832684248599599985333575 (resized).jpg17125361278994884805926314520377 (resized).jpg17125361278994884805926314520377 (resized).jpg
#30 3 months ago
Looks great. You will get terrible air balls off the front target post without the original style rubber. I found out the hard way. Another solution is to stack two of the type you have on now. https://www.marcospecialties.com/pinball-parts/38-6425
#31 3 months ago
Thx.
Chime unit/panel cleaned up. Marco sells a kit to easily replace grommets, bushings, etc.
17127864711441249981524005347360 (resized).jpg17127864711441249981524005347360 (resized).jpgIMG_20240409_180507006 (resized).jpgIMG_20240409_180507006 (resized).jpg
#32 3 months ago
Thx.
[quoted image][quoted image]
Looks great. Game will be awesome when your done!
$ 69.00
Pinball Pimp
$ 179.00
$ 119.95
Allteksystems
