(Topic ID: 245194)
Evel Knievel: Back box feature lights not working
By Brewchap
  • 13 posts
  • 4 Pinsiders participating
  • Latest reply 4 years ago by Brewchap
#1 4 years ago
Feature lights may not be the correct term to use, but I don't know what else to call them. The lights in question is on the back box, it's the Player 1 -5, High game to date, tilt, match, and game over. I have a new MPU and I have re-pinned all connectors that go to the MPU. I also have toned out the lamp wires from the back box to the MPU J1 which all toned out. I'm at a lost... Any suggestions?
#2 4 years ago
#3 4 years ago
After checking so more, I found that I am not getting power from the rectifier board
#4 4 years ago
Check your fuses to make sure one did not blow
#5 4 years ago
Fuse is good. I believe that J2 pin 7 is the correct pin location and I don't have any power coming from that pin on the rectifier board.
#6 4 years ago
Trace that wire back and see if it is cut or damaged anywhere.
#7 4 years ago
It tones good to the rectifier board
#8 4 years ago
Have you tried unplugging your connectors at your light driver board and plug in a back in and see if that helps or jiggle those wires that those connectors and see if they come on
#9 4 years ago
Yes, I tried jiggling the wires. I even put new connectors and repinned them.
I'm thinking that I might have a transformer problem because I'm not getting any power from the J1 pin 7.
What is the best was to test the transformer and rectifier board?
#10 4 years ago
Have you got 5.4 volts DC at TP1 on the rectifier board?
The backbox feature lamps come from the same transformer source as the playfield feature lamps. So if the playfield feature lamps are working it isn't a transformer issue.
Quoted from Brewchap:
J2 pin 7 at the rectifier board is line power return!
Feature lamp voltage for the backbox is J3 pin 6 at the rectifier board.
#11 4 years ago
#12 4 years ago
Yes I do have 5 volts DC on TP1.
I mean J1 instead of J2. That is were I toned out the wire to. I'll look at J3 pin 6 instead.
#13 4 years ago
I got 5 v DC now in my Backbox. I was chasing the wrong wire. The backbox connector needs to be re-pinned.
$ 179.00
$ 8.00
Third Coast Pinball
4,000 (OBO)
Queen Creek, AZ
$ 69.00
Pinball Pimp
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/evel-knievel-back-box-feature-lights-not-working and we tried optimising it for printing. Some page elements may have been deliberately hidden.
