So i have a very nice Evel i picked up. It has been in some moist areas and the connectors have gotten corroded. I just went and bought a new MPU alltek and checked everything out before installation. The board boots and the light go (no sound but i have not looked into that). I can start a game and it seems to go through every coil when i do that (standard it seems like most pins resetting everything) but here is where it gets weird.. it kicks out all of the balls right away. If you hit the very bottom drop target it makes the ball kick-out go, if you hit the middle drop target the ball kick-out continues indefinitely, and i have to shut the machine down. My guess is bad connections. Rather than repining every single connector, has anyone here done a bowl of soda powder and water then drying to get rid of corrosion? I am going to go through each board and reflow solder everywhere, but was looking for a better way to tackle the connectors. Any Ideas would be greatly appreciated. thanks
