(Topic ID: 15636)
Estimated Value?
By Mutato
11 years ago
  • 12 posts
  • 8 Pinsiders participating
  • Latest reply 11 years ago by donjagra
#1 11 years ago
How is the estimated value on here calculated? Is that for a grade A unit? and subtract from there?
#2 11 years ago
...What do you mean?
An item is only worth what someone will pay for it.
#3 11 years ago
The averages are from completed ebay auctions.
http://pinside.com/pinball/help/faq#faq12
#4 11 years ago
Also, keep in mind that over the past two years, prices have for the most part increased dramatically. Most of the estimated prices are low as a result.
#5 11 years ago
I guess I mean how do you grade a machine?
Damage to body would be less deduction than say a damaged playfield?
#6 11 years ago
So how would you rate this pin?
Is it a buy or a walk away? (it is not for sale but a pin I play at lunch)
// Error: Image 25955 not found // // Error: Image 25956 not found // // Error: Image 25957 not found //
#7 11 years ago
If that's the biggest issue, its a buy....
#8 11 years ago
Quoted from Mutato:
It is not that simple. There a ton of things that factor into the cost of a game.
Supply, demand, the seller, cosmetic issues, electrical issues, and that's just scratching the surface.
#9 11 years ago
It is complicate, but if it's within your price range and a pin you want, go get it.
#10 11 years ago
You need to turn it on, play it, check if the flippers/coils work and are strong.
Then go into switch test and see if all the switches work.
Then go into lamp test...check em all.
Then check the playfield for wear areas that you may need to repair.
Then rate the cabinet/backglass.
All of these affect the price of the pin. The more things wrong the more the price drops. But only to an extent. No pin I have ever bought is 100% even if I originally though it might be. Its like a living organism. Things will break and you will have to fix.
hth.
#11 11 years ago
Now that depends on price, distance from you etc
How much is it?
#12 11 years ago
What does the cliffhanger ramp entrance look like?
$ 69.99
£ 50.00
PinballToys
$ 54.99
$ 45.95
$ 95.00
Pinball Mod Co.
$ 1.29
Daddio's 3D Printed Mods
$ 27.00
3,950
San Diego, CA
$ 70.00
$ 19.99
$ 40.00
Pin Modster
Towson, MD
$ 49.99
$ 125.00
$ 34.99
Rubber/Silicone
NO GOUGE PINBALL™
£ 70.00
PinballToys
$ 18.95
This page was printed from https://pinside.com/pinball/forum/topic/estimated-value and we tried optimising it for printing. Some page elements may have been deliberately hidden.
