(Topic ID: 215621)
Escalera Question...
By pinster68
2 years ago
  • 19 posts
  • 11 Pinsiders participating
  • Latest reply 2 years ago by pinster68
    #1 2 years ago
    Just about to pull the trigger on an Escalera MS-60 through Larry at Flip N Out Pinball. I need to confirm if this is even going to work. My side entry landing is 35” x 42”, with stairs leading straight up into the house, and another staircase 90 degrees into the cellar. Looks something like this.
    #2 2 years ago
    Excellent choice! I’m sure Larry will chime in soon to help.
    #3 2 years ago
    I assume you’ll be heading down into the cellar? If so, I don’t believe it will work. You don’t have enough room to make that 90 degree turn. I have an ecsalera and also have a landing that requires a 90 degree turn and it doesn’t fit.
    #4 2 years ago
    Yeah, Larry was great on the phone and offered competitive pricing. Definitely using him over other outlets or used/Craigslist options.
    I’m thinking I’ll have no issue coming straight in the side, but then I’ll have to turn everything 90 degrees and slide the pin out over the cellar stairs a bit to pitch the Escalera back for the cellar stairs. I just don’t know if I’ve got the clearance for the turn.
    #5 2 years ago
    Quoted from DngrWillRobinson:
    Yes, heading into the cellar.
    #6 2 years ago
    So a cursory search of dimensions says a folded up pin is about 29" wide x 30" deep. I’m fine with removing the head if I need to.
    #7 2 years ago
    Just my opinion... I have an Escalera (from Larry!) and have made similar turns but on a slightly bigger landing. I think it will challenging with a folded pin. However, with the head removed, it shoukd be doable.
    #8 2 years ago
    Get it to the landing, take off the escalera, turn the pin, strap back to escalera and keep going.
    #9 2 years ago
    Quoted from Boat:
    That's what I do. I have a 180 degree turn that I have to wrestle with.
    #10 2 years ago
    A suggestion for those difficult landings is to put something down on the landing to make it easy to spin the Escalera and the pin. A rug, sheet, towel or something that is close to the size of the game plus the Escalera. It also helps prevent any scratches on the landing when you spin it. Then you will have to move the game close to the edge to be able to tip it back. This is a good application for the MS-60 as it gives you slightly more room but does make it a bit harder to tip the load back.
    Larry@flipnoutpinball.com
    #11 2 years ago
    Quoted from pinster68:
    Your 42" side is fine going up or down. Your 35" side is an issue. I don't believe 35" is enough clearance to make a turn. I have 38" and cannot make a turn with the escalera going down, head on.
    If you can open up the wall to create more clearance, it will help you.
    #12 2 years ago
    as stated you might have to unhook, turn and rehook on the landing. It will be tight and getting it back on teh wheels on the landing will be difficult but it should be doable. You night want a second person below to help guide as you get it back on the wheels to go down the second set of steps. But if there is anyway that it will work its a much better option than killing your back.
    #13 2 years ago
    How do you move the pins down now? If you can do it with a standard hand truck, you should be able to do it with an Escalera. You would definitely need a second person, as you will need to hang the pin way over the edge of the stairs in order to get enough leverage and room to tilt it back.
    #14 2 years ago
    Quoted from gweempose:
    I just moved into the house (btw, I’m now walking distance to the Silverball Museum ). All my pins are in a storage unit.
    #15 2 years ago
    Then I would check to see if there is room to rotate a pin on that landing before committing to the Escalera.
    #16 2 years ago
    I took my chances and ordered already. Worst case is I remove the head, which I’m perfectly fine with. It’s either that or I have to give up and sell all my pins. My cellar is the only place I can put them.
    #17 2 years ago
    You will love the Escalera. Best pinball investment I ever made.
    #18 2 years ago
    You know, dining rooms are highly overrated and really seldom used.....a fellow could easily fit six pins in a normal sized dining room. I know, because I tested it. I’m sure that I’m not the only one!
    #19 2 years ago
    Quoted from BALL_LESS1:
    That’s what we did in our last home. Had 5 pins there, with the rest of my collection in my garage. New house is a 100 year old classic with small rooms, and no garage, so no real choice in the matter for pins ... the 25’ x 25’ cellar will be my game room. I’m having it waterproofed and adding climate control. It should work out great aside from wrangling pins up and down. The escalera will make it about as good as I could hope.
    $ 12.00
    Pinball Photos
    Metal-Mods
    $ 24.00
    Pin Monk
    $ 90.00
    Lighting - Under Cabinet
    $ 49.00
    Bent Mods
    $ 69.50
    $ 54.99
    $ 200.00
    Professor Pinball
    $ 9.90
    Playfields
    The Super Fasteners
    $ 9,500.00
    Various Other Swag
    Shoot Again Pinball
    Operation Pinball
    $ 369.00
    $ 29.95
    Pinball Photos
    $ 54.99
    $ 79.95
    Hookedonpinball.com
    $ 5.00
    $ 59.95
    Hookedonpinball.com
    $ 95.00
    pinballmod
    $ 799.00
