Quoted from Oneangrymo:Well it’s a great machine well built and quality but for my application it didn’t work as planned it just doesn’t budge in carpet . Too unstable for me to mess with it more other then just lifting games up to change legs and adjust feet etc
That awesome collection deserves an Escalera so it fits in perfectly.
Everyone should always practice with the escalera before using one for a pinball machine, especially a damn heavy one. We recommend practicing using it without a load first. Then practice with something 100 pounds to get the feel of that shift in weight distribution when the steppers engage on the step. Then practice with a players condition game, etc.
Remember, the Escalera isn’t tilted back as far when going up and down stairs like a traditional hand truck. With traditional hand trucks the user leans it back so the slider belts assist. On the Escalera if you do the same, the slider belts will allow it to slide, which you won’t be expecting. So instead, it should be more of a 45 degree when going up the stairs and can be a bit more of an angle when going down, but not so much to hit the sliding belts.
The most important part when using the escalera is to have a good stance to support the weight shift and be ready for it (practice). But you should never be pulling the Escalera up the stairs when it’s loaded with a machine. No need to ever lift or pull, rather you are counterbalancing the weight shift.
Confused yet? Don’t be. It’s easy to learn and once you got it down, it’s as effortless as riding a bicycle. If I can do it, believe me, anyone can.
Final note, regardless of using an Escalera or a typical hand truck or 5 guys and a case of beer.... tight landings suck and JJP machines, B/W widebodies, and Multimorphic P3s are VERY heavy!
