Quoted from ScottinSGFNY:I have I believe the MS-66 model Escalara that I bought used. Charger died last year and battery is dead this year.
I need to replace both pieces - any suggestions of what model Battery & Battery Charger I need and where I can buy them?
The ones on my unit I don't believe were the factory originals - I am pretty sure they were cheaper replacements.
Thank You for any advice!
I sell all the replacement parts for Escalera.
There are two batteries available. One is an extended life version but for our market I recommend the standard battery PN 621. Its a 17 amp hour gel filled battery. Battery charger is PN 1463. Depending on how old your unit is you can also order the harness adapter to adapt to the new style connector.
Your model number and year built is on the side on the frame.
Call me anytime and I can help you get the parts you need.
larry
flipnoutpinball.com
847-778-4876
