Hello, in switch test, the left flipper EOS is not registering? I replaced the switch and that didn’t solve anything? Any ideas where to go from here? Thank you!
Broken wire at one of the other EOS switches in the game.
Broken wire from EOS not working to fliptronics board.
Quoted from LTG:Broken wire at one of the other EOS switches in the game.
Okay. All wires look good? So does EOS connector on board?
Quoted from Jimmyhonda:So does EOS connector on board?
Quoted from LTG:Broken wire from EOS not working to fliptronics board.
Page 2-6 in the manual is the layout of the Fliptronics board. Connector J906 is for the EOS switches. Page 3-2 in the manual is the switch matrix, right hand column is the dedicated switches like EOS and flipper button optos.
Check continuity of each wire from the EOS not working to the Fliptronics board. Figure out which of the two has a break. Then follow the wires to try and find it.
If you don't have a manual, you can download it from - https://www.ipdb.org/search.pl
For fliptronics games, is a functioning EOS switch really all that necessary? I read that the fliptronics board can compensate and work without the EOS switch?
Quoted from kevmad:For fliptronics games, is a functioning EOS switch really all that necessary? I read that the fliptronics board can compensate and work without the EOS switch?
Not that necessary. Though it's nice to not have that credit dot.
This page was printed from https://pinside.com/pinball/forum/topic/eos-switch-on-left-flipper-not-working-on-flinstones and we tried optimising it for printing. Some page elements may have been deliberately hidden.
