Hey there. I am fixing up a long neglected tri-zone and it is almost done (so happy and amazed). I think I am down to the last problem.
When the "N drop target" (switch 33) closes, the entire Row of switches (on the matrix, row 1) sometimes close as well. This includes the outhole, so you only get three hits on that drop target. I lifted all the diodes on every switch in that row and they all check out. There is some board damage on the small IC's next to IC11 (which I believe drive the switch matrix. Is it possible that this chip is also my problem for the row? Or should I be looking for a transistor somewhere?
I know the photos look scary, but I have good continuity everywhere the traces are supposed to go. Looks like the previous owner had a board fire and someone paid to have it repaired.
Thanks so much in advance with what I hope is this last little step in restoring a game (fingers crossed)
Edit: I forgot to mention that this board has been bulletproofed as per Vid's guide. The SCANBE's are all gone, the header between the boards has been replaced, and the faulty resistors were all beefed up. And just for completeness, I did just fix the +5V logic on this game by installing a new psu5 to replace a faulty voltage regulator. Somehow, I doubt that is the problem in this case.
