(Topic ID: 217608)
Emperor Ming Needs A Makeover
By timab2000
5 years ago
  • 27 posts
  • 10 Pinsiders participating
  • Latest reply 5 years ago by Stoomer
#1 5 years ago
I finished my Star Trek makeover, so I am starting on the makeover of my Flash Gordon.
I personally don't care for the factory paint scheme, so I am going to update Emperor Ming to reflect a somewhat more modern appearance. A 2.0 upgrade if you will.
Some may like it, some won't. Hell I may not like it after I am done, but I guess that is way God made sandpaper, and paint, so we'll see.
More to follow.........
#2 5 years ago
Here's a sneak peek............
#3 5 years ago
I kinda dig it.
#4 5 years ago
Nice! Im in the process of getting mine back up and running after a repaint...
Looking forward to what you do!
CD533046-F2DF-46BF-89CF-8E9AAA1912DB (resized).jpegCD533046-F2DF-46BF-89CF-8E9AAA1912DB (resized).jpeg
#5 5 years ago
Quoted from Spitfiren8:
Looks good! I'll post more as things progress. It's been a lot of work.
#6 5 years ago
Ok made some more progress today.
This stencil is the hardest one I have done, I have only done one other one, so I am not sure if that is saying much, but this is way harder than the Star Trek stencil I did. More little detail areas.
I am using a different paint, from what I used to do the Star Trek, only because I could not find the correct red. It is still Rustoleum, regular version I guess, but not the 2X stuff that Rustoleum makes. This stuff seems to be more runny and thin than the other stuff. Not sure what's up with that, but it is making everything a lot harder.
There is still 2 more stencils to lay down, so I have my work cut out. This stencil is from Pinball Pimp and it is only the 2nd one he has sold like this. So if you search around you might find the other Flash Gordon with this stencil kit. I have decided to try and stay with the Gold, Red and Black colors with a little bit of silver, to hopefully match the back box glass better. We'll see how it turns out.
I'll post more when I can..........
#7 5 years ago
Looking good to this point.
#8 5 years ago
Mr. Von Sydow, we hardly knew ye...
#9 5 years ago
Well catastrophic failure today!!!
Was working on the front of the cabinet laying down the black, all was going good untill....... it came time to remove the stencil. A good portion of the silver lightning bolts came off with the stencil.
Needless to say, I am majorly bumming out so much so I can post a picture of it yet. Not sure what I am going to do.
#10 5 years ago
Was able to get the back box done! I think it turned out pretty good. Not nearly as difficult as the cabinet.
On the cabinet disaster, I was able to remove what was left of the silver by simply using blue painters tape over the silver and it all pulled right off. Really disappointing. I would not recommend using the silver paint in the picture. It just would not stay on like the other paints pictured, not sure why.
So on to plan B on the cabinet......
#11 5 years ago
I lost a little of my gold in a few spots too. In hindsight i wouldnt have used the metallic paint. I used the same rustoleum as you did.
The metallic doesnt bond well to gloss paint, i should have done a light layer of flat first maybe?
#12 5 years ago
Yeah I am not sure why the silver did not stick. The gold was not problem at all. So I guess I am just going with the gold and black only.
I will have to see how good I am at masking my own lighting bolts on the front cabinet, since I used the one for the silver, which was actually supposed to be white. I did not like the look of that.
#13 5 years ago
Ok I got the 2nd stencil on one side of the cabinet laid down today. It was supposed to be sprayed white like shown above. Was going to use silver, but that did not go as planned.
So I went with gold, and did a outline in the circle with black to kind of get some contrast, or whatever you want to call it. Went pretty well.
The last stencil will be the hardest and should really be a challenge. Lots of small tiny pieces that will have to be removed without screwing up the gold and red. It will give the letters a blocked 3D look. Well see....
#14 5 years ago
Ok moving forward I got the last stencil laid down and finished on one side of the cabinet. Overall I think it turned out pretty good.
Was a lot of working getting all the small vinyl pieces off. Took a lot of time, and that made the paint dry before I was ready, which caused some slight problems with stringy paint going back in the red color. I think most of it will clean up and I can touch up anything that is left. One more side to do and then I can start getting it back together.
Next post I should have the legs on, which have all been repainted and looking good, and back box installed.
#15 5 years ago
Looks great....are you going to color match the side rails and/or legs to this color scheme or go original?
#16 5 years ago
Quoted from Captive_Ball:
Well I have them painted original right now, legs that is, but I might change that depending on how it looks. Side rails I don't know???? We'll see.....
#17 5 years ago
All stenciling is completed and I am real happy with the end results.
I still have a lot of work to do getting everything back into the cabinet and back box. I think it is a HUGE difference from what I started with in the beginning with the faded and kind of boring factory paint scheme.
20180508_131214 (resized).jpg20180508_131214 (resized).jpg20180508_131221 (resized).jpg20180508_131221 (resized).jpg20180602_155506 (resized).jpg20180602_155506 (resized).jpg20180602_155517 (resized).jpg20180602_155517 (resized).jpg
#18 5 years ago
Looks great, hopefully you dont run into issues like i did when i reinstalled everything...
#19 5 years ago
Looks great. I like it better than original. Makes it look a bit more modern.
#20 5 years ago
What problems did you have??
#21 5 years ago
Looks great!
I like the main cab but would rather have the original backbox sides
#22 5 years ago
Quoted from timab2000:
Im having a weird reset issue with the left pop bumper switch, some controlled lamps inop and some solenoids not firing. Hopefully connector repons will fix most bit the reset is strange...
#23 5 years ago
Looks sharp....nicely done
#24 5 years ago
Great idea and work. Looks good. Factory looking but better than their idea.
#25 5 years ago
"Modern"as in... I mean it looks like a system 11 pin now.
Great work!
#26 5 years ago
Nice job dude! Tastefully done & looks great, especially those bolts that wrap around the legs
#27 5 years ago
Very Nice...I normally don't like changing originals but this one is an exception...well done!!
And thanks for posting the original for those of us who didn't know what the original looks like...IPDB doesn't have any good cabinet pics...
Sean
$ 29.00
RoyGBev Pinball
Berkeley Springs, WV
$ 18.95
Hardware
Volcano Pinball
Cabinet Parts
Volcano Pinball
Troxel Repair
$ 7.00
$ 100.00
Volcano Pinball
$ 69.00
Pinball Pimp
$ 5.00
Hardware
Volcano Pinball
5,000 (OBO)
Houston, TX
$ 29.00
RoyGBev Pinball
7,995 (OBO)
$ 179.00
Retro Electro Designs
Hardware
Volcano Pinball
$ 99.00
Playfield - Plastics
$ 22.95
$ 119.95
Allteksystems
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/emperor-ming-needs-a-makeover and we tried optimising it for printing. Some page elements may have been deliberately hidden.
