Quoted from Hi-Fi:I was referring to the second stacked switch on the right flipper. When the EOS opens this switch closes. At least I think it is supposed to close. That's how it's set to work on my machine.
That second stacked switch on the main flipper EOS switch activates the upper right flipper and actually isn't part of the matrix.
Sorry, I wasn't clear about that above. The matrix switch for the right outlane flipback flipper is actually the second stacked switch on the right cabinet flipper button. Check the diode on that switch. The schematics say this right cabinet flipback flipper switch is wired to the playfield switch connector (J2) at the MPU board, not the cabinet switch connector (J3) at the MPU board, but anyway.
As you may or may not know, the switch test in service mode will only show the lowest logical switch number that's closed, i.e. if you press and hold the "A" Rollover, the player displays will flash "12", but if you then drop the ball in the outhole, the player displays will flash "08" and the closed "A" rollover switch "12" won't be displayed again until you remove the ball from the outhole.
So with this in mind, going through the switches backwards, can you try this when you get a few spare minutes:
1) Make sure all drop targets are reset up. Remove the ball from the outhole.
2) Go to the switch test in service mode. The Match/Ball In Play display should show "0"
3) Activate and release one switch at a time starting from the highest number switch working down towards the lowest number switch. When you get to the drop targets, drop one then lift it and move to the next.
Does any switch report the wrong number in the player displays when you close it?
See the attached diagram showing the switch numbers in Blue. Highest logical switch number starts at the bottom right corner and finishes with the lowest switch number at the top left.
